My Jetson Xavier NX has booted up but is stuck
My Jetson Xavier NX has booted up but is stuck on a black screen as shown in the video.
How should I fix this? Please guide me.
please use UART to see if you can still login to the system.
OK, I will do it and tell you the result later.
@DaveYYY I follow your advice, the result is below. What shall I do next?
So you tried OTA update but failed?
Then can you re-flash the device with SDK Manager?
@DaveYYY I didn’t try OTA update but I’m not sure what I do wrong, by the way I will re-flash the device with SDK Manager and tell you later about result.
