Could not download the image successfully either via wget or normal browser. I tried 3 times with my PC and once via mobile phone. At some point it gets frozen.
Hi yusufbaylav,
I can download it by Chrome browser without problem just now, would you please try it again or see if can download other doc/file from Jetson Download Center | NVIDIA Developer to confirm if that’s local network issue?
There’s not any problem related to starting a download, the problem is it fails after some time in the middle.
And additionally, a few Mbs vs. a few Gbs … I do not believe that will ease the way that I download the image. Why don’t you provide these images in the format of a normal linux distribution image which we can download directly either via torrent or via wget/curl. If it fails at some point it does not even continue from where it has left.
As I guessed, file is corrupted. Although it seems completed trying to burn the file to the micro sd resulted with an error. Please provide me an healthy link to download the image. I could not start to play with the device and it costed me more than 10GB of my mobile internet. And I got nothing healthy in my hand. It cannot be a network issue as I tried both with home internet and mobile many times.
It has been days, no solution provided. I found a better connection speed and downloaded it. But it should definitely be more than 40Mbit/sec. Please provide these images with a better system. Starting to play/touch the system should not take multiple days long and should not cost this much!
