Passive -S: V4L2 first programs SerDes (lock + gold), then SIPL starts → still ICP timeout / 0 frames
Tried / failed
Attempt
Result
Match dphyRate 800Mbps + des 0415=0x39
NVCSI=800M; still 0 frames
osc_manual free-run (no MFP2)
Start OK; still timeout
-u disableSubframe
no effect
Export Sensing HAL extension IMixedPipelineLayout::IsMixedYuvModule()=true
immediate board hang/reboot
Mid-run I2C / KILL on stop
often KASAN vi_capture_request_unpin → host unreachable
Core question
With SerDes proven by V4L2 and by passive mode, where should we look next on the SIPL Camera HAL → NVCSI/VI capture path for GMSL YUV422?
Specifically:
For YUV422 packed UYVY on GMSL, is exporting IsMixedYuvModule required? Our export with patched HAL causes reboot — is there a supported JP7.2 path without that private UUID?
Why does V4L2 log VI capture setup complete (channel_id=0, csi_stream=2, vc=1) while SIPL often only shows RCE VI ch[35] UYVY config, then ICP timeout (as if no MIPI packets arrive)?
Is there a known PixPack / VC / stream binding issue for csi-cd + vcIdDst=1 + MAX96724 2x4 mode?
Correct JSON tokens + HAL expectations for Thor GMSL YUV ICP (beyond forum note of "422" + "uyvy")?
We are looking for guidance on the remaining HAL/NVCSI/VI gap (not SerDes programming). Happy to provide full SIPL log + V4L2/SIPL dmesg side-by-side.
Is this your basis? If so you may want to git pull it; or clone it. Sensing updated its binaries 5 days ago. You could try the
`nvidia-jetson-camera-drivers/Jetson AGX Thor Devkit/TRD1_G2A/JetPack7.2/TRD1_G2A_AGX_THOR_SIPL_JP7.2_L4TR39.2/query/trd1_g2a/sgx_yuv_gmsl2.json’ for sipl query
git clone --filter=blob:none --no-checkout \
https://github.com/SENSING-Technology/nvidia-jetson-camera-drivers.git
cd nvidia-jetson-camera-drivers
git sparse-checkout init --cone
git sparse-checkout set "Jetson AGX Thor Devkit/TRD1_G2A/JetPack7.2/TRD1_G2A_AGX_THOR_SIPL_JP7.2_L4TR39.2"
git checkout main
We compared the Sensing TRD you linked (TRD1_G2A … SIPL JP7.2 L4TR39.2). Our board already has the same md5 for libnvcamerahal.so, SGX YUV module, and sgx_yuv_gmsl2.json — reinstalling doesn’t help.
Our setup is OEM, not TRD reference: MAX96724_B @0x2E / csi-cd / Link B + MAX9295@0x40 + ISX031C UYVY 1920×1536 (not stock SGX_YUV / MAX96717).
We aligned OEM IMixedPipelineLayout to the SGX .so (UUID + vtable + IsMixedYuvModule()=true). Results:
MixedYuv only → no hang, but GetImageAttributes / AllocateBuffers fail
MixedYuv + OEM_FORCE_UYVY=1 → board hang/reboot
FORCE only (no MixedYuv) → Init/Start OK, VI/RCE UYVY + 800 Mbps, SerDes=V4L2 gold (incl. passive -S), still ICP_CAPTURE_TIMEOUT / 0 frames
Q: For OEM MAX9295+MAX96724, how should YUV ICP get past GetImageAttributes without FORCE, and why does FORCE+MixedYuv crash? With FORCE-only, what else is missing on HAL→NVCSI/VI when SerDes is already proven by V4L2?
Following returns reasonably good output that might be useful. I don’t have a isx031c to fully test. Using Sensings’s nvsipl_camera -v 4 logged CQueryAdapter: forcing sensor GW5 vc to YUV422/uyvy, followed by Mixed YUV output: sensor 0 (YUV422) → ICP UYVY passthrough.
Tested nvsipl_query --output-json, as below, both normally and inside a mount namespace overriding /usr/lib/nvsipl_drv with SENSING’s ./driver/*.so; the outputs were identical. nvsipl_query still reports GW5 as RAW12.
Hi @whitesscott,
Thanks again for the Sensing TRD / `--mixed-yuv-output` notes.
we got ICP UYVY frames on our OEM path (ISX031C + MAX9295 + MAX96724 Link B / `csi-cd`). Main fixes were des VC remap to **VC0** (SIPL/VI listens vc=0; V4L2 gold was often VC1), plus keeping VIDEO_LOCK (`01FC=0x81`) / FSYNC through Start. Working with `OEM_FORCE_UYVY=1` only — MixedYuv UUID not needed.
after a good capture, can your Sensing `nvsipl_camera --mixed-yuv-output` run **Stop → Deinit → exit** without rebooting Thor?
On our side: `Stop`+drain is OK; `Deinit()` (or process `_exit` without Deinit) still causes a full reboot. Earlier we also saw `vi_capture_request_unpin` in `tegra_camera`. V4L2 streamoff/on is fine on the same VI.
If teardown is clean on your TRD setup, any ordering tips or known JP7.2/R39.2 VI patches would help. If not, is long-lived SIPL (no Deinit) the expected workaround for now?
Three things that may be relevant and could produce a Thor reboot.
Calling Stop or Deinit from the signal handler. The API contract in NvSIPLCamera.hpp explicitly forbids it (Signal handler: No on both) and Deinit() is documented Async/Sync: Async. The reference sample handler only sets a quit flag and then re-arms every signal to SIG_IGN so a second Ctrl-C can’t skip cleanup — the comment in the source spells it out:
/usr/src/jetson_sipl_api/sipl/samples/camera/main.cpp
static void SigHandler(int signum) {
LOG_WARN("Received signal: %u. Quitting\n", signum);
signal(SIGINT, SIG_IGN);
signal(SIGTERM, SIG_IGN);
signal(SIGQUIT, SIG_IGN);
signal(SIGHUP, SIG_IGN);
bQuit = true;
// Do NOT restore to SIG_DFL - a second Ctrl-C would kill the process
// before upMaster->Stop() and upMaster->Deinit() can execute,
causing RCE FW crash.
Ordering is Stop → drain → per-object Deinit →
upMaster->Deinit() LAST.
From samples/camera/main.cpp:3784-3900 the reference sequence is:
Between Stop and Deinit the sample also spins the event queue with a 1 ms timeout until it sees two consecutive empty cycles — that’s the “let RCE finish flushing” window. If you Deinit before every notification handler has been Stop’d, a late frame-complete lands on a pool that’s already being torn down and you may get the unpin bug.
Deinit() is Async and it is the call that unregisters NvSciBufs. The header comment: “Any registered images are automatically deregistered and can be safely destroyed.” If the process returns
from main() before Deinit() has actually completed (or you _exit() from a handler), the kernel-side capture channel still holds pinned dmabuf handles → vi_capture_request_unpin KASAN on release. Wait for Deinit() to return NVSIPL_STATUS_OK and log it before you fall out of main.
The R39.2 UDDF release notes list “Resiliency: Runtime error recovery and automatic driver restart after transient failures are not yet supported” as a known limitation (Release Notes — NVIDIA Jetson Linux Developer Guide).
