We are using Jetson Xavier NX hardware decoder to decode image stream (running at 10fps). Image resolution is 1920x1200. The decoder crashes with Segmentation Fault randomly. Upon debugging with gdb, we found that it’s crashes at this function NvVideoJPEGDecoderPinYUVSurface ()
GDB log:
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000ffffac0b38ec in NvVideoJPEGDecoderPinYUVSurface () from /usr/lib/aarch64-linux-gnu/tegra/libnvvideo.so
[Current thread is 1 (LWP 10963)]
(gdb) up
#1 0x0000ffffae061a6c in NvMediaIJPDRenderYUV () from /usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so
(gdb) up
#2 0x0000ffffb11c8900 in jpegTegraDecoderRender () from /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so
(gdb)
#3 0x0000ffffb11a2a88 in jpeg_read_raw_data () from /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so
(gdb)
#4 0x0000aaaab4900c74 in NvJPEGDecoder::decodeToFd (this=0xaaaaf3cfcf80, fd=@0xaaaaf3caeaf0: 73, in_buf=0xffff6824a010 "\377\330\377", <incomplete sequence \333>, in_buf_size=232901,
pixfmt=@0xffff1a72d62c: 43690, width=@0xffff1a72d624: 65535, height=@0xffff1a72d628: 4090942640) at /usr/src/jetson_multimedia_api/samples/common/classes/NvJpegDecoder.cpp:135
135 jpeg_read_raw_data (&cinfo, NULL, cinfo.comp_info[0].v_samp_factor * DCTSIZE);
Details on the SW:
- JP 5.1
- JPEG decoder is used in a Qt app and the decoded image is displayed in the app
- Single threaded decoding loop
- Incoming JPEG stream is from another NX (using NX’s HW encoder) over ethernet and with ROS.
