您好,以下描述的是JPEG编解码耗时统计,请问从数据上是否合理?是否存在可优化空间?
JPEG编解码耗时统计:
- JPEG编码接口调用关系:NvBufSurfaceFromFd → Raw2NvBufSurface → encodeFromFd
JPEG编码耗时统计:
* ORIN/200万像素Camera: 4465.84us
* ORIN/800万像素Camera: 11747.72us
- JPEG解码接口调用关系:decodeToFd → NvBufSurfaceFromFd → NvBufSurface2Raw → gpuConvertI420toBGR
JPEG解码耗时统计:
* ORIN/200万像素Camera: 8962.67us
* ORIN/800万像素Camera: 28447.52us
DaneLLL
4
For encoding, the flow looks optimal.
For decoding, you may try like:
decodeToFd → NvBufSurfaceFromFd → NvBufSurfTransform → RGBA → convert RGBA to BGR through CUDA code
This may have further performance enhancement but you would need to implement converting RGBA to BGR through CUDA.
请问:从 … NvBufSurfTransform→ RGBA → convert RGBA to BGR through CUDA code,有使用示例吗?
There is no existing CUDA code for converting RGBA to BGR, and you would need to implement it on your own.
system
Closed
9
convert_bgr.zip (4.7 KB)
md5sum convert_bgr.zip
51ae0331b592fc8fc2204255e7f0e03f convert_bgr.zip
Please refer to the example.
Verified environment:
In the zip file contain:
convert_bgr
├── jpeg_convert_bgr.cpp
└── patch
- move patch and
to /usr/src/jetson_multimedia_api/samples/06_jpeg_decode/
- execute below command
sudo git apply patch
sudo make
# save the Image with raw format
./jpeg_decode num_files 1 ${Image}.jpg ${Image} --convert-bgr
- After above commands will generate
${Image}.bgr
, and you could use YUView
to check the format
