hi,
i working jetson nx with jetpack 5.0.1 and deepstream6.1.
i have a question about kafka,
i moved kafka codes which similar test4 to all_box_generated probe of deepstream_app_main.c,
but it can not create topic automatically and no objects data at all, i think this should be similar with test5 procedure and all_box_generated probe should correct place in deepstream_app pipline,
i also tried overlay probe, but no topic and objects, too.
pls advice where is problem?
• DeepStream Version
• TensorRT Version
• The pipeline being used
test5 is correct of course.
i used few probes in my project to customize plug in and less places already…
for kafka, it is better put in all_box_gennerated probe and similar as test5, that probe is blank in my project and i think it is possible should be there.
hi,
do you need add probe on the src pad? where to add that?
and this is my codes attatched, other parts is similar with test4 and i am sure that can generate msg informations correctly because i tried all my codes in deepstream-app.c and kafka is ok.
but it is some conflict with somewhere of my project so i have to move kafka to all_box_generated probe.
all box generated probe is right place.
but i am also interesting how to add a new more probe at where?
because my project is a little complicated and few customized functions in my pipline, pls give more advice how to add more probes in deepstream-main-app.c.
i know how to add probe at dynamic pipline yes,
i mean you should advice a place to me where to add that in deepstream pipline, and osd src pad was used by my other customized application already.
and tiler element is tiled_display or tiler_tee in deepstream?
i have added a kafka probe at appctx->primary gie and got objects informations correctly.
i use it firstly in project temporarily.
but i want to get sgie object.
so had better you advice a right place for me and no need test one by one to save time…
and now’s quesiton is rtsp losts frames after i add probe, but rtsp can run it is ok. only some while losts frames or a little scratch screen.
should i destroy that probe?
could you give some advice for the problem?
Yeah, the gstreamer probe function actually is synchronous,it will block the whole pipeline data flow. So if your probe function takes a long time, we suggest you create a new thread.
