I have tried to set 'DP_AUX_CH1 P/N ’ as ‘i2c_clk/dat’ in ‘tegra194-p2888-0001-p2822-0000-common.dtsi’, according to ‘./kernel/nvidia/Documentation/devicetree/bindings/pinctrl/nvidia,tegra186-dpaux-pinctrl.txt’.
The system still cannot be started ,it has new reasons.
285 i2c@31e0000 {
286 pinctrl-names = "default";
287 pinctrl-0 = <&dpaux_default>;
288 bmi160@69 {
289 compatible = "bmi,bmi160";
290 reg = <0x69>;
291 accelerometer_matrix = [01 00 00 00 01 00 00 00 01];
292 gyroscope_matrix = [01 00 00 00 01 00 00 00 01];
293 status = "okay";
294 };
295 };
296
297+ /* DPAUX1 muxed to I2C mode */
298+ i2c@3190000 {
299+ pinctrl-names = "default";
300+ pinctrl-0 = <&dpaux1_default>;
301+ };
302
303
304 host1x {
305 dpaux@155F0000 {
306 status = "okay";
307 compatible = "nvidia,tegra194-dpaux3-padctl";
308 /delete-property/ power-domains;
309 dpaux_default: pinmux@0 {
310 dpaux3_pins {
311 pins = "dpaux3-3";
312 function = "i2c";
313 };
314 };
315 };
316
317+ dpaux@155D0000 {
318+ status = "okay";
319+ compatible = "nvidia,tegra194-dpaux1-padctl";
320+ /delete-property/ power-domains;
321+ dpaux1_default: pinmux@0 {
322+ dpaux1_pins {
323+ pins = "dpaux1-1";
324+ function = "i2c";
325+ };
326+ };
327+ };
328 };
329
console output:
[0001.323] I> 22) Base:0x00000000 Size:0x00000000
[0001.328] I> 23) Base:0xe8ce0000 Size:0x00020000
[0001.332] I> 24) Base:0xee000000 Size:0x02000000
[0001.336] I> 25) Base:0x40050000 Size:0x00002000
[0001.341] I> 26) Base:0x40040000 Size:0x00006000
[0001.345] I> 27) Base:0xe9800000 Size:0x00400000
[0001.350] I> 28) Base:0xecc00000 Size:0x01400000
[0001.354] I> 29) Base:0xe9400000 Size:0x00400000
[0001.359] I> 30) Base:0x00000000 Size:0x00000000
[0001.363] I> 31) Base:0x00000000 Size:0x00000000
[0001.368] I> 32) Base:0xf8000000 Size:0x08000000
[0001.372] I> 33) Base:0xf0000000 Size:0x08000000
[0001.377] I> 34) Base:0xebc00000 Size:0x01000000
[0001.381] I> 35) Base:0xaa000000 Size:0x01000000
[0001.386] I> 36) Base:0xa0000000 Size:0x0a000000
[0001.390] I> 37) Base:0xea800000 Size:0x00800000
[0001.394] I> 38) Base:0x80000000 Size:0x20000000
[0001.399] I> 39) Base:0xb0000000 Size:0x08000000
[0001.403] I> 40) Base:0x00000000 Size:0x00000000
[0001.408] I> 41) Base:0x00000000 Size:0x00000000
[0001.412] I> 42) Base:0x00000000 Size:0x00000000
[0001.417] I> 43) Base:0x00000000 Size:0x00000000
[0001.421] I> 44) Base:0x00000000 Size:0x00000000
[0001.426] I> 45) Base:0x00000000 Size:0x00000000
[0001.430] GIC-SPI Target CPU: 0
[0001.433] Interrupts Init done
[0001.436] calling constructors
[0001.439] initializing heap
[0001.442] I> Heap: [0xa068d430 ... 0xaa000000]
[0001.446] initializing threads
[0001.449] initializing timers
[0001.452] creating bootstrap completion thread
[0001.456] top of bootstrap2()
[0001.459] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.463] initializing platform
[0001.466] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.472] W> device prod register failed
[0001.475] I> Bl_dtb @0xa9f00000
[0001.478] I> gpio framework initialized
[0001.489] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.496] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.497] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.508] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.515] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.519] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.525] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.534] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.541] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.547] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.555] I> fixed regulator driver initialized
[0001.566] I> register 'maxim' power off handle
[0001.567] I> virtual i2c enabled
[0001.567] I> registered 'maxim,max20024' pmic
[0001.569] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.575] I> Boot-device: eMMC
[0001.578] I> Boot_device: SDMMC_BOOT instance: 3
[0001.585] I> sdmmc-3 params source = boot args
[0001.587] I> sdmmc bdev is already initialized
[0001.591] I> sdmmc-3 params source = boot args
[0001.598] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.603] I> Found 37 partitions in SDMMC_USER (instance 3)
[0001.607] E> "plugin-manager" doesn't exist, creating
[0001.611] E> "ids" doesn't exist, creating
[0001.616] E> "connection" doesn't exist, creating
[0001.620] E> "configs" doesn't exist, creating
[0001.626] I> Find /i2c@3160000's alias i2c0
[0001.628] I> Reading eeprom i2c=0 address=0x50
[0001.659] I> Device at /i2c@3160000:0x50
[0001.659] I> Reading eeprom i2c=0 address=0x56
[0001.659] E> I2C: slave not found in slaves.
[0001.660] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.661] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.661] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.669] E> eeprom: Failed to read I2C slave device
[0001.674] I> Eeprom read failed 0x3526070d
[0001.678] I> Find /i2c@3180000's alias i2c2
[0001.682] I> Reading eeprom i2c=2 address=0x54
[0001.687] E> I2C: slave not found in slaves.
[0001.690] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.698] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.703] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.713] E> eeprom: Failed to read I2C slave device
[0001.718] I> Eeprom read failed 0x3526070d
[0001.722] I> Reading eeprom i2c=2 address=0x57
[0001.726] E> I2C: slave not found in slaves.
[0001.730] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.738] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.743] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.753] E> eeprom: Failed to read I2C slave device
[0001.758] I> Eeprom read failed 0x3526070d
[0001.762] I> Reading eeprom i2c=2 address=0x52
[0001.766] E> I2C: slave not found in slaves.
[0001.770] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.778] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.783] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.793] E> eeprom: Failed to read I2C slave device
[0001.798] I> Eeprom read failed 0x3526070d
[0001.803] I> Find /i2c@c240000's alias i2c1
[0001.806] I> Reading eeprom i2c=1 address=0x52
[0001.811] E> I2C: slave not found in slaves.
[0001.814] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.822] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.828] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.837] E> eeprom: Retry to read I2C slave device.
[0001.842] E> I2C: slave not found in slaves.
[0001.846] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.854] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.859] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.869] E> eeprom: Failed to read I2C slave device
[0001.874] I> Eeprom read failed 0x3526070d
[0001.878] I> Reading eeprom i2c=1 address=0x50
[0001.882] E> I2C: slave not found in slaves.
[0001.886] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.894] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.899] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.909] E> eeprom: Retry to read I2C slave device.
[0001.914] E> I2C: slave not found in slaves.
[0001.918] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.926] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.931] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.941] E> eeprom: Failed to read I2C slave device
[0001.946] I> Eeprom read failed 0x3526070d
[0001.950] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0001.955] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.966] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0001.974] E> "i2c@3160000" doesn't exist, creating
[0001.978] E> "module@0x50" doesn't exist, creating
[0001.983] I> Adding plugin-manager/cvm
[0001.986] E> "chip-id" doesn't exist, creating
[0001.990] I> Adding plugin-manager/chip-id/A02
[0001.994] I> Plugin-manager override starting
[0002.000] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.008] I> node /plugin-manager/fragement-soft-wdt matches
[0002.015] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.023] I> node /plugin-manager/fragment-p2888@0 matches
[0002.035] I> Disable plugin-manager status in FDT
[0002.035] I> Plugin-manager override finished successfully
[0002.047] I> enabling 'vdd-hdmi-5v0' regulator
[0002.053] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.053] I> hdmi cable connected
[0002.056] E> set volts not configured for 'vdd-1v0'
[0002.058] E> set volts not configured for 'vdd-1v8-hs'
[0002.063] E> invalid display type
[0002.068] E> invalid display type
[0002.070] E> cannot find any other nvdisp nodes
[0002.086] I> edid read success
[0002.086] I> width = 640, height = 480, frequency = 25174825
[0002.087] I> width = 1366, height = 768, frequency = 85500000
[0002.087] I> Best mode Width = 640, Height = 480, freq = 25174825
[0002.093] I> hdmi_enable, starting HDMI initialisation
[0002.098] I> hdmi_enable, HDMI initialisation complete
[0002.101] I> Load in CBoot Boot Options partition and parse it
[0002.106] E> Error -9 when finding node with path /boot-configuration
[0002.111] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.118] I> Hit any key to stop autoboot: 4 3 2 1
[0004.126] initializing target
[0004.126] calling apps_init()
[0004.127] starting app kernel_boot_app
[0004.130] I> found decompressor handler: lz4-legacy
[0004.130] I> decompressing BMP blob ...
[0004.135] I> Kernel type = Normal
[0004.136] I> Loading kernel & kernel-dtb from removable storage (5)
[0004.137] I> No sdcard
[0004.137] I> -0 params source =
[0004.137] E> Blockdev open: exit error
[0004.137] I> Loading kernel & kernel-dtb from removable storage (6)
[0004.148] W> No valid slot number is found in scratch register
[0004.148] W> Return default slot: _a
[0004.153] I> USB Firmware Version: 60.05 release
[0004.608] E> failed to initialize xhci controller
[0004.609] E> Error in init of XUSB host driver, err: 79790026
[0004.609] W> Failed to initialize device 6-0
[0004.609] I> Loading kernel/boot.img from built-in storage ...
[0004.610] W> No valid slot number is found in scratch register
[0004.610] W> Return default slot: _a
[0004.612] I> A/B: bin_type (37) slot 0
[0004.616] I> Loading partition kernel at 0xa4410000 from device(0x1)
[0004.998] W> No valid slot number is found in scratch register
[0004.999] W> Return default slot: _a
[0004.999] I> A/B: bin_type (38) slot 0
[0004.999] I> Loading partition kernel-dtb at 0x90000000 from device(0x1)
[0005.003] I> T19x: Authenticate boot.img (bin_type: 37), max size 0x4000000
[0005.343] I> T19x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type: 38), max size 0x400000
[0005.348] I> Kernel hdr @0xa4410000
[0005.348] I> Kernel dtb @0x90000000
[0005.349] I> Checking boot.img header magic ... [0005.349] I> [OK]
[0005.349] I> Valid boot.img @ 0xa4410000
[0005.349] I> decompressor handler not found
[0005.350] I> Copying kernel image (34048008 bytes) from 0xa4410800 to 0x80080000 ... [0005.369] I> Done
[0005.369] I> Move ramdisk (len: 0) from 0xa6489800 to 0x91000000
[0005.371] I> Updated bpmp info to DTB
[0005.372] I> Ramdisk: Base: 0x91000000; Size: 0x0
[0005.373] I> Updated initrd info to DTB
[0005.375] W> WARN: Fail to override "console=none" in commandline
[0005.381] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0005.388] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0005.395] W> No valid slot number is found in scratch register
[0005.401] W> Return default slot: _a
[0005.404] I> Active slot suffix:
[0005.407] I> add_boot_slot_suffix: slot_suffix =
[0005.412] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x140000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[0005.450] I> Updated bootarg info to DTB
[0005.454] W> MAC addr invalid!
[0005.457] E> Failed to get WIFI MAC address
[0005.461] W> MAC addr invalid!
[0005.464] E> Failed to get Bluetooth MAC address
[0005.468] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:e9:76
[0005.475] E> "plugin-manager" doesn't exist, creating
[0005.480] I> Adding /chosen/plugin-manager/cvm
[0005.484] E> "chip-id" doesn't exist, creating
[0005.488] I> Adding /chosen/plugin-manager/chip-id
[0005.493] E> "configs" doesn't exist, creating
[0005.497] I> Adding /chosen/plugin-manager/configs
[0005.502] E> "ids" doesn't exist, creating
[0005.506] I> Adding /chosen/plugin-manager/ids
[0005.510] E> "odm-data" doesn't exist, creating
[0005.514] I> Adding /chosen/plugin-manager/odm-data
[0005.523] E> "memory" doesn't exist, creating
[0005.524] I> [0] START: 0x80000000, END: 0xab000000
[0005.528] I> [1] START: 0xab004000, END: 0xe8cd0000
[0005.532] I> [2] START: 0xe8cdc000, END: 0xe8ce0000
[0005.537] I> dram_block larger than 80000000
[0005.541] I> [3] START: 0x100000000, END: 0x480000000
[0005.546] I> added [base:0x80000000, size:0x2b000000] to /memory
[0005.552] I> added [base:0xab200000, size:0x3da00000] to /memory
[0005.558] I> added [base:0x100000000, size:0x380000000] to /memory
[0005.565] I> Updated memory info to DTB
[0005.568] E> add_disp_param: failed to get display params for du=1
[0005.574] E> "reset" doesn't exist, creating
[0005.578] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0005.583] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0005.587] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0005.592] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0005.597] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0005.601] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0005.606] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0005.611] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0005.616] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0005.621] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0005.626] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0005.630] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0005.635] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0005.640] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0005.645] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0005.650] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0005.656] E> "misc-data" doesn't exist, creating
[0005.659] I> Boot-device: eMMC
[0005.662] I> Add boot-sdmmc to plugin-manager/misc-data
[0005.667] I> Add storage-sdmmc to plugin-manager/misc-data
[0005.672] W> Unknown storage device
[0005.676] I> Add serial number:0424318031918 as DT property
[0005.682] I> Plugin-manager override starting
[0005.686] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0005.693] I> node /plugin-manager/fragement-soft-wdt matches
[0005.701] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0005.709] I> node /plugin-manager/fragment-p2888@0 matches
[0005.722] I> Disable plugin-manager status in FDT
[0005.722] I> Plugin-manager override finished successfully
[0005.722] I> tegrabl_load_kernel_and_dtb: Done
[0005.723] I> Sending TOS params
[0005.725] I> Sending NS DRAM Ranges to TOS
[0005.729] W> Failed to send NS DRAM Ranges to TOS
[0005.733] W> Failed to lock interface between BL and TOS
[0005.745] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (gcs@gcs-ubuntu1804) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #15 SMP PREEMPT Tue Jul 9 10:42:16 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3da00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00140000@a0697000
[ 0.000000] Found lut_mem: 00002008@a0692000
[ 0.000000] Found vpr, start=0xf0000000 size=8000000[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffda6000 s53400 r8192 d32616 u94208
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4033698
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x140000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29240(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 16001716K/16390900K available (15166K kernel code, 2914K rwdata, 6612K rodata, 8512K init, 605K bss, 323648K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000008] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009218] Console: colour dummy device 80x25
[ 0.012429] console [tty0] enabled
[ 0.015614] bootconsole [tegra_comb_uart0] disabled
<hit enter to activate fiq debugger>
[ 0.020886] kmemleak: Kernel memory leak detector disabled
[ 0.020965] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.021027] pid_max: default: 32768 minimum: 301
[ 0.022641] Security Framework initialized
[ 0.023471] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023510] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.026138] ftrace: allocating 46802 entries in 183 pages
[ 0.452359] sched-energy: Sched-energy-costs installed from DT
[ 0.452478] ASID allocator initialised with 65536 entries
[ 0.495407] tegra-id: chipid=21917.
[ 0.495476] tegra-id: opt_subrevision=0.
[ 0.495529] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.495623] DTS File Name: /home/gcs/work/public_sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.495682] DTB Build time: Jul 9 2019 11:11:23
[ 0.545278] CPU1: Booted secondary processor [4e0f0040]
[ 0.577529] CPU2: Booted secondary processor [4e0f0040]
[ 0.609950] CPU3: Booted secondary processor [4e0f0040]
[ 0.642263] CPU4: Booted secondary processor [4e0f0040]
[ 0.674535] CPU5: Booted secondary processor [4e0f0040]
[ 0.707083] CPU6: Booted secondary processor [4e0f0040]
[ 0.739143] CPU7: Booted secondary processor [4e0f0040]
[ 0.740299] Brought up 8 CPUs
[ 0.740575] SMP: Total of 8 processors activated.
[ 0.740613] CPU features: detected feature: Privileged Access Never
[ 0.740651] CPU features: detected feature: LSE atomic instructions
[ 0.740689] CPU features: detected feature: User Access Override
[ 0.740726] CPU features: detected feature: 32-bit EL0 Support
[ 0.748254] CPU: All CPU(s) started at EL2
[ 0.748380] alternatives: patching kernel code
[ 0.764068] devtmpfs: initialized
[ 0.842785] Initilizing CustomIPI irq domain
[ 0.843264] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.843320] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.846596] pinctrl core: initialized pinctrl subsystem
[ 0.846864] OS set in device tree is not L4T.
[ 0.847242] regulator-dummy: no parameters
[ 0.847584] Initializing plugin-manager
[ 0.847662] Plugin module not found
[ 0.848798] Plugin-manager status disabled
[ 0.850541] NET: Registered protocol family 16
[ 0.852983] pstore: using zlib compression
[ 0.854452] console [pstore-1] enabled
[ 0.854483] pstore: Registered ramoops as persistent store backend
[ 0.854519] ramoops: attached 0x200000@0xe8a00000, ecc: 0/0
[ 0.870144] cpuidle: using governor menu
[ 0.871733] bpmp: waiting for handshake
[ 0.871803] bpmp: handshake completed
[ 0.871892] bpmp: synchronizing channels
[ 0.871925] bpmp: channels synchronized
[ 0.871960] bpmp: mail init ok
[ 0.876129] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.876482] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.876528] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.876563] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.876601] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.876637] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.876676] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.876724] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.876776] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.876816] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.876854] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.881878] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.882205] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.886693] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.888254] Registering BPMP clocks...
[ 0.888479] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.889032] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.889740] tegra_powergate_init: DONE
[ 0.889991] DTS File Name: /home/gcs/work/public_sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.890130] DTB Build time: Jul 9 2019 11:11:23
[ 0.894283] Tegra reboot handler registered.
[ 0.904308] iommu: Adding device 14180000.pcie to group 0
[ 0.905354] iommu: Adding device 14100000.pcie to group 1
[ 0.906416] iommu: Adding device 14140000.pcie to group 2
[ 0.907486] iommu: Adding device 141a0000.pcie to group 3
[ 0.909364] iommu: Adding device 2490000.ether_qos to group 4
[ 0.910172] iommu: Adding device 3100000.serial to group 5
[ 0.911033] iommu: Adding device 3110000.serial to group 6
[ 0.911645] iommu: Adding device 3140000.serial to group 7
[ 0.912433] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.912746] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.912843] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.912904] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.912962] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.913078] tegra-pmc: PMC Prod config success
[ 0.913448] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.913553] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.914090] iommu: Adding device 3460000.sdhci to group 8
[ 0.914976] iommu: Adding device 3400000.sdhci to group 9
[ 0.915853] iommu: Adding device c260000.spi to group 10
[ 0.916947] iommu: Adding device 3160000.i2c to group 11
[ 0.917593] iommu: Adding device c240000.i2c to group 12
[ 0.918191] iommu: Adding device 3180000.i2c to group 13
[ 0.918814] iommu: Adding device 3190000.i2c to group 14
[ 0.919629] iommu: Adding device 31b0000.i2c to group 15
[ 0.920260] iommu: Adding device 31c0000.i2c to group 16
[ 0.920871] iommu: Adding device c250000.i2c to group 17
[ 0.921502] iommu: Adding device 31e0000.i2c to group 18
[ 0.922676] iommu: Adding device sound to group 19
[ 0.923510] iommu: Adding device 3510000.hda to group 20
[ 0.924378] iommu: Adding device bc00000.rtcpu to group 21
[ 0.927476] iommu: Adding device 13e10000.host1x to group 22
[ 0.928239] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.928839] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.929455] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.930037] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.930883] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.931615] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.932230] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.932841] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.933670] iommu: Adding device 15340000.vic to group 31
[ 0.934320] iommu: Adding device 15380000.nvjpg to group 32
[ 0.934777] iommu: Adding device 15500000.tsec to group 33
[ 0.935266] iommu: Adding device 15100000.tsecb to group 34
[ 0.935752] iommu: Adding device 15480000.nvdec to group 35
[ 0.936177] iommu: Adding device 15140000.nvdec1 to group 36
[ 0.936661] iommu: Adding device 154c0000.nvenc to group 37
[ 0.937116] iommu: Adding device 15a80000.nvenc1 to group 38
[ 0.937745] iommu: Adding device 15880000.nvdla0 to group 39
[ 0.938353] iommu: Adding device 158c0000.nvdla1 to group 40
[ 0.939147] iommu: Adding device 15200000.nvdisplay to group 41
[ 0.939530] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(140000)
[ 0.939644] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0692000(3000)
[ 0.941016] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.941102] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.941741] iommu: Adding device 15210000.nvdisplay to group 42
[ 0.941870] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.944712] iommu: Adding device 15c10000.vi to group 43
[ 0.945081] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.945613] iommu: Adding device 14800000.isp to group 44
[ 0.947580] iommu: Adding device 16000000.pva0 to group 45
[ 0.948408] iommu: Adding device 16800000.pva1 to group 46
[ 0.949027] iommu: Adding device 15810000.se to group 47
[ 0.949645] iommu: Adding device 15820000.se to group 48
[ 0.950056] iommu: Adding device 15830000.se to group 49
[ 0.950489] iommu: Adding device 15840000.se to group 50
[ 0.950932] iommu: Adding device c1a0000.aon to group 51
[ 0.952894] iommu: Adding device d000000.bpmp to group 52
[ 0.953399] bpmp: ping status is 0
[ 0.953596] bpmp d000000.bpmp: firmware tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
[ 0.957632] bpmp d000000.bpmp: probe ok
[ 0.959632] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 0.960332] iommu: Adding device smmu_test to group 53
[ 0.961780] mc: mapped MMIO address: 0xffffff800a560000 -> 0x2c10000
[ 0.961879] mc: mapped MMIO address: 0xffffff800a580000 -> 0x2c20000
[ 0.961969] mc: mapped MMIO address: 0xffffff800a5a0000 -> 0x2c30000
[ 0.962055] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c40000
[ 0.962143] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c50000
[ 0.962231] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2b80000
[ 0.962352] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2b90000
[ 0.962446] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2ba0000
[ 0.962534] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2bb0000
[ 0.962620] mc: mapped MMIO address: 0xffffff800b050000 -> 0x1700000
[ 0.962706] mc: mapped MMIO address: 0xffffff800b070000 -> 0x1710000
[ 0.962794] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1720000
[ 0.962883] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1730000
[ 0.962970] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1740000
[ 0.963057] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1750000
[ 0.963177] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1760000
[ 0.963276] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1770000
[ 0.963435] mc-err: mcerr ops are set to t19x
[ 0.972155] iommu: Adding device 2600000.dma to group 54
[ 0.979778] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.980327] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.988551] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.989039] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.991922] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.991999] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.993081] iommu: Adding device 3550000.xudc to group 55
[ 0.994157] iommu: Adding device 3610000.xhci to group 56
[ 0.997611] arm64_ras arm64_ras: probed
[ 0.998222] ras_fhi_enable: FHI 475 enabled on CPU0
[ 0.998324] ras_fhi_enable: FHI 476 enabled on CPU1
[ 0.998483] ras_fhi_enable: FHI 477 enabled on CPU2
[ 0.998605] ras_fhi_enable: FHI 478 enabled on CPU3
[ 0.998730] ras_fhi_enable: FHI 479 enabled on CPU4
[ 0.998859] ras_fhi_enable: FHI 480 enabled on CPU5
[ 0.998969] ras_fhi_enable: FHI 481 enabled on CPU6
[ 0.999113] ras_fhi_enable: FHI 482 enabled on CPU7
[ 0.999447] carmel_ras_enable: RAS enabled on cpu0
[ 0.999742] carmel_ras_enable: RAS enabled on cpu1
[ 1.000068] carmel_ras_enable: RAS enabled on cpu2
[ 1.000425] carmel_ras_enable: RAS enabled on cpu3
[ 1.000746] carmel_ras_enable: RAS enabled on cpu4
[ 1.001018] carmel_ras_enable: RAS enabled on cpu5
[ 1.001318] carmel_ras_enable: RAS enabled on cpu6
[ 1.001655] carmel_ras_enable: RAS enabled on cpu7
[ 1.001834] carmel_ras carmel_ras: probed
[ 1.003734] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 1.004538] tegra-cbb c600000.aon-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.005803] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.007157] tegra-cbb be00000.rce-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.008416] tegra-cbb b600000.sce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 1.009024] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.012553] vdd-3v3-cvb: 3300 mV
[ 1.012988] vdd-1v8-cvb: 1800 mV
[ 1.013524] vdd-1v8-sd: 1800 mV
[ 1.014108] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.014253] vdd-epb-1v0: 1000 mV
[ 1.014772] vdd-sdmmc1-sw: 3300 mV
[ 1.015306] avdd-cam-2v8: 2800 mV
[ 1.015964] vdd-sata-1v5: 1500 mV
[ 1.016389] vdd-1v8-slt: 1800 mV
[ 1.016839] vdd-3v3-slt: 3300 mV
[ 1.017269] vdd-fan: 5000 mV
[ 1.017805] vdd-hdmi-5v0: 5000 mV
[ 1.018340] vdd_sys_en: 1200 mV
[ 1.019005] vdd-5v-sata: 5000 mV
[ 1.019493] vdd-ac-bat: 5000 mV
[ 1.019834] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.055653] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.061626] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.062153] SCSI subsystem initialized
[ 1.062776] usbcore: registered new interface driver usbfs
[ 1.062887] usbcore: registered new interface driver hub
[ 1.063085] usbcore: registered new device driver usb
[ 1.069910] tegra-i2c 3190000.i2c: could not find pctldev for node /host1x/dpaux@155D0000/pinmux@0, deferring probe
[ 1.075664] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.078952] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.087144] vdd-1v0: at 1000 mV
[ 1.095104] vdd-1v8-hs: at 1800 mV
[ 1.103142] vdd-1v8-ls: at 1800 mV
[ 1.107189] vdd-1v8-ao: at 1800 mV
[ 1.115216] vddio-ddr-1v1: at 1100 mV
[ 1.122976] vdd-rtc: at 800 mV
[ 1.124456] spmic-ldo1: at 2375 mV
[ 1.135078] vdd-ao-3v3: at 3300 mV
[ 1.147133] vddio-emmc-3v3: at 3300 mV
[ 1.148739] spmic-ldo4: at 1587 mV
[ 1.157161] vdd-usb-3v3: at 3300 mV
[ 1.165270] vddio-sdmmc1-3v3: at 3300 mV
[ 1.169341] vdd-csi-1v2: at 1200 mV
[ 1.171179] spmic-ldo8: at 1800 mV
[ 1.173434] GPIO line 246 (gpio_default) hogged as output/high
[ 1.175044] GPIO line 247 (gpio_default) hogged as output/high
[ 1.175642] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.179497] max77620 4-003c: max77620 probe successful
[ 1.180284] media: Linux media interface: v0.10
[ 1.180393] Linux video capture interface: v2.00
[ 1.182037] pps_core: LinuxPPS API ver. 1 registered
[ 1.182095] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.182301] PTP clock support registered
[ 1.183185] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.183290] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.184864] tegra_fiq_debugger_init: found FIQ source (IRQ 467)
[ 1.186907] Advanced Linux Sound Architecture Driver Initialized.
[ 1.187610] Bluetooth: Core ver 2.22
[ 1.187715] NET: Registered protocol family 31
[ 1.187768] Bluetooth: HCI device and connection manager initialized
[ 1.187844] Bluetooth: HCI socket layer initialized
[ 1.187909] Bluetooth: L2CAP socket layer initialized
[ 1.187992] Bluetooth: SCO socket layer initialized
[ 1.191459] camchar: rtcpu character device driver loaded
[ 1.195347] clocksource: Switched to clocksource arch_sys_counter
[ 1.252133] VFS: Disk quotas dquot_6.6.0
[ 1.252328] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.252775] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.254879] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.255076] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.255182] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.255322] nvmap_page_pool_init: Total RAM pages: 4016813
[ 1.255376] nvmap_page_pool_init: nvmap page pool size: 502101 pages (1961 MB)
[ 1.255745] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.256248] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.258220] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.274525] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.275002] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.275433] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.275800] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.276369] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.276762] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.276991] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.278513] la/ptsa driver initialized.
[ 1.278981] NET: Registered protocol family 2
[ 1.280324] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.281095] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.281905] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.282035] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.282401] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.283111] NET: Registered protocol family 1
[ 1.283938] RPC: Registered named UNIX socket transport module.
[ 1.283998] RPC: Registered udp transport module.
[ 1.284045] RPC: Registered tcp transport module.
[ 1.284091] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.284464] Trying to unpack rootfs image as initramfs...
[ 1.309233] host1x 13e10000.host1x: initialized
[ 1.312630] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.318619] audit: initializing netlink subsys (disabled)
[ 1.318728] audit: type=2000 audit(0.900:1): initialized
[ 1.319927] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.330973] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.332726] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.333578] 9p: Installing v9fs 9p2000 file system support
[ 1.339934] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.340265] io scheduler noop registered
[ 1.340622] io scheduler cfq registered (default)
[ 1.342907] random: fast init done
[ 1.345033] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.383414] iommu: Adding device 2993000.adsp to group 57
[ 1.487323] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[ 1.488526] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.506019] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.506664] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.507390] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.510955] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.511409] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.511504] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.516048] tsec 15500000.tsec: initialized
[ 1.518753] tsec 15100000.tsecb: initialized
[ 1.524754] nvdec 15480000.nvdec: initialized
[ 1.528386] nvdec 15140000.nvdec1: initialized
[ 1.535613] falcon 15340000.vic: initialized
[ 1.538227] falcon 15380000.nvjpg: initialized
[ 1.540978] falcon 154c0000.nvenc: initialized
[ 1.543601] falcon 15a80000.nvenc1: initialized
[ 1.548118] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.552004] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.555861] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.559795] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.563261] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.565106] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.566936] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.568860] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.573734] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.579752] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.580235] scare-pigeon 14b00000.isp-thi: initialized
[ 1.591629] pva 16000000.pva0: initialized
[ 1.624569] pva 16800000.pva1: initialized
[ 1.656024] nvdla 15880000.nvdla0: initialized
[ 1.687397] nvdla 158c0000.nvdla1: initialized
[ 1.691717] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.691933] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.691996] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.692058] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.693773] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.693848] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.693960] tegradccommon 15200000.dc_common: dma mapping done
[ 1.695156] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.695373] generic_infoframe_type: 0x87
[ 1.695585] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.695716] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 1.702163] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.702273] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.702339] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.703430] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.703490] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.705300] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=50347983
[ 1.707886] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.707963] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.709268] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.710878] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.711767] kfuse 3830000.kfuse: initialized
[ 1.714231] tegradc 15200000.nvdisplay: probed
[ 1.720695] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.724199] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.725679] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.726695] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.187127] console [ttyTCU0] enabled
[ 4.187623] Console: switching to colour frame buffer device 80x30
[ 4.187744] [drm] Initialized
[ 4.199928] tegradc 15200000.nvdisplay: fb registered
[ 4.205529] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.211315] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.216143] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.218758] brd: module loaded
[ 4.226169] loop: module loaded
[ 4.228162] tegra_profiler: version: 1.132, samples/io: 46/26
[ 4.234144] tegra_profiler: auth: init
[ 4.238371] nct1008_nct72 4-004c: starting parse dt
[ 4.238856] THERMAL EST: found 3 subdevs
[ 4.238860] THERMAL EST num_resources: 0
[ 4.238864] [THERMAL EST subdev 0]
[ 4.238868] [THERMAL EST subdev 1]
[ 4.238871] [THERMAL EST subdev 2]
[ 4.239327] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.239329] THERMAL EST: thz register success.
[ 4.239533] THERMAL EST: end of probe, return err: 0
[ 4.239831] Parent Clock set for DC plld3
[ 4.240554] hisi_sas: driver version v1.6
[ 4.245621] libphy: Fixed MDIO Bus: probed
[ 4.247445] tun: Universal TUN/TAP device driver, 1.6
[ 4.247448] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.248285] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.248288] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.248338] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.248340] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.248427] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.248429] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.248480] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.248482] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.250105] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.254434] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb e9 76
[ 4.254554] libphy: dwc_phy: probed
[ 4.257278] PPP generic driver version 2.4.2
[ 4.257502] PPP BSD Compression module registered
[ 4.257505] PPP Deflate Compression module registered
[ 4.257523] PPP MPPE Compression module registered
[ 4.257527] NET: Registered protocol family 24
[ 4.257598] usbcore: registered new interface driver r8152
[ 4.257649] usbcore: registered new interface driver asix
[ 4.257698] usbcore: registered new interface driver ax88179_178a
[ 4.257741] usbcore: registered new interface driver cdc_ether
[ 4.257805] usbcore: registered new interface driver net1080
[ 4.257858] usbcore: registered new interface driver cdc_subset
[ 4.257903] usbcore: registered new interface driver zaurus
[ 4.257959] usbcore: registered new interface driver cdc_ncm
[ 4.258174] VFIO - User Level meta-driver version: 0.3
[ 4.259626] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.259641] ehci-pci: EHCI PCI platform driver
[ 4.259687] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.259698] ohci-pci: OHCI PCI platform driver
[ 4.259752] ohci-platform: OHCI generic platform driver
[ 4.267745] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.267750] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.270964] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.274571] usbcore: registered new interface driver uas
[ 4.274664] usbcore: registered new interface driver usb-storage
[ 4.274745] usbcore: registered new interface driver usbserial
[ 4.278289] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.278344] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.278934] tegra-i2c c240000.i2c: no acknowledge from address 0x8
[ 4.278990] ucsi_ccg 1-0008: read version failed
[ 4.278995] ucsi_ccg 1-0008: get_fw_info fail,, err=-121
[ 4.279036] ucsi_ccg: probe of 1-0008 failed with error -121
[ 4.279660] mousedev: PS/2 mouse device common for all mice
[ 4.279760] usbcore: registered new interface driver xpad
[ 4.306879] tegradc 15200000.nvdisplay: hdmi: tmds rate:50349K prod-setting:prod_c_hdmi_0m_54m
[ 4.307557] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.307572] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
[ 4.307577] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.308145] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.308148] Extcon AUX2(HDMI) enable
[ 4.308955] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor1
[ 4.308998] generic_infoframe_type: 0x87
[ 4.309099] tegradc 15210000.nvdisplay: DT parsed successfully
[ 4.309153] tegradc 15210000.nvdisplay: Display dc.ffffff800d0d0000 registered with id=1
[ 4.309485] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 4.309492] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[b][ 4.311996] tegradc 15210000.nvdisplay: hdmi: can't get adpater for ddc bus 3
[ 4.312004] tegradc 15210000.nvdisplay: hdmi: can't get adpater for scdc bus 3
[ 4.312104] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 4.312108] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 4.312210] Unable to handle kernel read from unreadable memory at virtual address ffffffc3ec70fc30[/b]
[ 4.312212] Mem abort info:
[ 4.312214] ESR = 0x8600000d
[ 4.312218] Exception class = IABT (current EL), IL = 32 bits
[ 4.312219] SET = 0, FnV = 0
[ 4.312221] EA = 0, S1PTW = 0
[ 4.312225] swapper pgtable: 4k pages, 39-bit VAs, pgd = ffffff800a193000
[ 4.312252] [ffffffc3ec70fc30] *pgd=00e8000440000711, *pud=00e8000440000711
[ 4.312259] Internal error: Oops: 8600000d [#1] PREEMPT SMP
[ 4.312314] Modules linked in:
[ 4.312321] CPU: 0 PID: 64 Comm: kworker/u16:2 Not tainted 4.9.140-tegra #15
[ 4.312323] Hardware name: jetson-xavier (DT)
[ 4.312351] Workqueue: events_unbound async_run_entry_fn
[ 4.312354] task: ffffffc3ed327000 task.stack: ffffffc3ecf94000
[ 4.312359] PC is at 0xffffffc3ec70fc30
[ 4.312401] LR is at tegra_edid_read_block+0xc0/0x280
[ 4.312409] pc : [<ffffffc3ec70fc30>] lr : [<ffffff80085e1758>] pstate: 80c00045
[ 4.312411] sp : ffffffc3ecf97750
[ 4.312417] x29: ffffffc3ecf97750 x28: ffffff800b001088
[ 4.312423] x27: ffffffc3eb3f9818 x26: ffffff800940e848
[ 4.312429] x25: ffffffc3ecf977d0 x24: 0000000000000000
[ 4.312437] x23: 0000000000000000 x22: 0000000000000002
[ 4.312442] x21: ffffffc3eafe9700 x20: ffffff8008fdd130
[ 4.312449] x19: 0000000000000000 x18: 0000000000000001
[ 4.312455] x17: 0000000000004650 x16: 0000000000004670
[ 4.312460] x15: ffffffffffffffff x14: ffffffffffffffff
[ 4.312465] x13: 0000000000000008 x12: 0000000000000008
[ 4.312471] x11: 0088000000000000 x10: 0101010101010101
[ 4.312477] x9 : 0000000000000000 x8 : 0000000000000000
[ 4.312482] x7 : 0000000000000030 x6 : ffffffc3ecf977be
[ 4.312488] x5 : 0000000000000050 x4 : ffffffc3ecf977bf
[ 4.312492] x3 : ffffffc3ec70fc30 x2 : 0000000000000002
[ 4.312498] x1 : ffffffc3ecf977d0 x0 : ffffffc3ecf61530
[ 4.312500]
[ 4.312504] Process kworker/u16:2 (pid: 64, stack limit = 0xffffffc3ecf94000)
[ 4.312507] Call trace:
[ 4.312513] [<ffffffc3ec70fc30>] 0xffffffc3ec70fc30
[ 4.312520] [<ffffff80085e1e9c>] tegra_edid_get_monspecs+0x74/0xbe8
[ 4.312527] [<ffffff80085ca784>] tegra_dc_set_fbcon_boot_mode+0x134/0x1b8
[ 4.312535] [<ffffff8008629208>] tegra_dc_hdmi_init+0x790/0xb38
[ 4.312547] [<ffffff80085c480c>] tegra_dc_set_out+0x2ac/0x490
[ 4.312555] [<ffffff80085c62f4>] tegra_dc_probe+0x8e4/0x1668
[ 4.312563] [<ffffff800876cd18>] platform_drv_probe+0x60/0xc0
[ 4.312570] [<ffffff800876a398>] driver_probe_device+0xd8/0x408
[ 4.312575] [<ffffff800876a7a4>] __driver_attach+0xdc/0x128
[ 4.312583] [<ffffff8008767e14>] bus_for_each_dev+0x5c/0xa8
[ 4.312588] [<ffffff8008769b98>] driver_attach+0x30/0x40
[ 4.312594] [<ffffff80087683d0>] driver_attach_async+0x20/0x60
[ 4.312600] [<ffffff80080dfc48>] async_run_entry_fn+0x48/0x158
[ 4.312608] [<ffffff80080d4f3c>] process_one_work+0x1e4/0x4b0
[ 4.312613] [<ffffff80080d5258>] worker_thread+0x50/0x4c8
[ 4.312619] [<ffffff80080dbee4>] kthread+0xec/0xf0
[ 4.312625] [<ffffff8008083850>] ret_from_fork+0x10/0x40
[ 4.312635] ---[ end trace f77d3251d6ad1877 ]---
[ 4.321795] Unable to handle kernel paging request at virtual address ffffffffffffffd8
[ 4.321797] Mem abort info:
[ 4.321800] ESR = 0x96000005
[ 4.321803] Exception class = DABT (current EL), IL = 32 bits
[ 4.321804] SET = 0, FnV = 0
[ 4.321806] EA = 0, S1PTW = 0
[ 4.321808] Data abort info:
[ 4.321810] ISV = 0, ISS = 0x00000005
[ 4.321812] CM = 0, WnR = 0
[ 4.321816] swapper pgtable: 4k pages, 39-bit VAs, pgd = ffffff800a193000
[ 4.321822] [ffffffffffffffd8] *pgd=0000000000000000, *pud=0000000000000000
[ 4.321827] Internal error: Oops: 96000005 [#2] PREEMPT SMP
[ 4.321833] Modules linked in:
[ 4.321840] CPU: 0 PID: 64 Comm: kworker/u16:2 Tainted: G D 4.9.140-tegra #15
[ 4.321842] Hardware name: jetson-xavier (DT)
[ 4.321923] task: ffffffc3ed327000 task.stack: ffffffc3ecf94000
[ 4.321930] PC is at kthread_data+0x24/0x30
[ 4.321936] LR is at wq_worker_sleeping+0x20/0xd0
[ 4.321940] pc : [<ffffff80080dcad4>] lr : [<ffffff80080d6380>] pstate: 804000c5
[ 4.321941] sp : ffffffc3ecf97380
[ 4.321948] x29: ffffffc3ecf97380 x28: ffffffc3ed327000
[ 4.321953] x27: ffffffc3ee2f0000 x26: 0000000000000000
[ 4.321959] x25: ffffff80080ec114 x24: ffffffc3ffdb1cc0
[ 4.321964] x23: ffffffc3ed3276c8 x22: ffffff80097f4000
[ 4.321970] x21: ffffff8009e28000 x20: ffffff80097ff000
[ 4.321975] x19: ffffffc3ed327000 x18: 0000000000000011
[ 4.321980] x17: 000000000000000e x16: 0000000000000007
[ 4.321986] x15: 0000000000000000 x14: 0000000000000019
[ 4.321991] x13: 0000000000000033 x12: 000000000000004c
[ 4.321996] x11: 0000000000000068 x10: 0000000000000018
[ 4.322001] x9 : 0000000000000000 x8 : 0000000000000400
[ 4.322006] x7 : 0000000000000000 x6 : 0000000000000400
[ 4.322013] x5 : 0000000000006000 x4 : 00000000025c17d5
[ 4.322018] x3 : 0000000000000000 x2 : 0000000074bc5b48
[ 4.322024] x1 : ffffffc3ffdb1cc0 x0 : 0000000000000000
[ 4.322025]
[ 4.322029] Process kworker/u16:2 (pid: 64, stack limit = 0xffffffc3ecf94000)
[ 4.322030] Call trace:
[ 4.322038] [<ffffff80080dcad4>] kthread_data+0x24/0x30
[ 4.322049] [<ffffff8008f3f298>] __schedule+0x418/0x780
[ 4.322058] [<ffffff80080ec114>] do_task_dead+0x74/0x78
[ 4.322067] [<ffffff80080b9aa8>] do_exit+0x6f8/0xa08
[ 4.322076] [<ffffff800808c528>] bug_handler.part.2+0x0/0x88
[ 4.322084] [<ffffff80080a31fc>] __do_kernel_fault.isra.1+0x144/0x218
[ 4.322090] [<ffffff80080a3408>] do_page_fault+0x60/0x518
[ 4.322094] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 4.322099] [<ffffff8008082904>] el1_da+0x24/0xb4
[ 4.322106] [<ffffff80085e1e9c>] tegra_edid_get_monspecs+0x74/0xbe8
[ 4.322112] [<ffffff80085ca784>] tegra_dc_set_fbcon_boot_mode+0x134/0x1b8
[ 4.322120] [<ffffff8008629208>] tegra_dc_hdmi_init+0x790/0xb38
[ 4.322129] [<ffffff80085c480c>] tegra_dc_set_out+0x2ac/0x490
[ 4.322136] [<ffffff80085c62f4>] tegra_dc_probe+0x8e4/0x1668
[ 4.322143] [<ffffff800876cd18>] platform_drv_probe+0x60/0xc0
[ 4.322150] [<ffffff800876a398>] driver_probe_device+0xd8/0x408
