Kernel Panic in Soft Interrupt Context with JetPack 6.0
When using JetPack 6.0, the kernel crashes in the soft interrupt context. The kernel logs are attached.
Is there a patch available to fix this issue?
dmesg-ramoops-0.txt (106.6 KB)
This issue appears to be related to LiveKit, as it only started occurring after we integrated LiveKit.
The ramoops is almost 100% Realtek RTW: RM: 802.11k spam because that driver is noisy; both panics happen ~0.4s after an RM cycle because that is all pstore captured.
LiveKit
LiveKit is a plausible trigger, not the kernel bug:
  • audio → tegra210_adma cyclic virt-dma
  • WebRTC UDP → rtl8852bu(O) (out-of-tree)
