Summary:
While running on an NVIDIA Orin Nano with kernel 5.10.120-rt70-tegra
, a warning occurred in clk_prepare_lock
during pm_runtime_work
. The issue seems linked to the SPI driver (tegra_spi_runtime_suspend
) and power management. The CAN module (mttcan
) also reported message loss in queue Q0. This could indicate a conflict or mismanagement in runtime power or clock handling.
2024-12-09 10:12:14.873
oksbot69 journald kernel------------[ cut here ]------------
oksbot69 journald kernelWARNING: CPU: 5 PID: 50116 at drivers/clk/clk.c:168 clk_prepare_lock+0x8c/0xa0
2024-12-09 10:12:14.874
oksbot69 journald kernelModules linked in: can_raw can tcp_diag inet_diag xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink ip6table_nat ip6table_filter ip6_tables iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter br_netfilter overlay lzo_rle lzo_compress zram iwlmvm ramoops reed_solomon mac80211 loop tcp_bbrplus sch_fq nvgpu aes_ce_blk crypto_simd cryptd iwlwifi aes_ce_cipher ghash_ce cp210x sha2_ce usbserial sha256_arm64 sha1_ce cfg80211 pwm_fan leds_gpio ina3221 userspace_alert tegra_bpmp_thermal imx290(O) spi_tegra114 binfmt_misc nvmap mttcan can_dev ip_tables x_tables [last unloaded: mtd]
oksbot69 journald kernelCPU: 5 PID: 50116 Comm: kworker/5:2 Tainted: G O 5.10.120-rt70-tegra #2
oksbot69 journald kernelHardware name: Rapyuta Robotics Jiri (DT)
oksbot69 journald kernelWorkqueue: pm pm_runtime_work
oksbot69 journald kernelpstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
oksbot69 journald kernelpc : clk_prepare_lock+0x8c/0xa0
oksbot69 journald kernellr : clk_prepare_lock+0x48/0xa0
oksbot69 journald kernelsp : ffff80002cdf3c10
oksbot69 journald kernelx29: ffff80002cdf3c10 x28: ffffd9da09dd9000
oksbot69 journald kernelx27: ffff80002e813ca8 x26: 0000000000000008
oksbot69 journald kernelx25: ffff80002cdf3d68 x24: ffffd9da0824f800
oksbot69 journald kernelx23: 0000000000000001 x22: ffff3ccc00be0110
oksbot69 journald kernelx21: 000000000000000a x20: ffffd9da0a144758
oksbot69 journald kernelx19: ffffd9da0a144740 x18: 0000000000000000
oksbot69 journald kernelx17: 0000000000000000 x16: ffffd9da089e2450
oksbot69 journald kernelx15: 0000000000000000 x14: 000000000000002f
oksbot69 journald kernelx13: 0000000000000032 x12: 0000000000000024
oksbot69 journald kernelx11: 0000000000000040 x10: 0000000000000ae0
oksbot69 journald kernelx9 : ffff3ccc1f50b16c x8 : fefefefefefefeff
oksbot69 journald kernelx7 : 0000000000000018 x6 : ffff3ccc00e50ec0
oksbot69 journald kernelx5 : ffff80002cdf3b58 x4 : ffffd9da0a144770
2024-12-09 10:12:14.875
oksbot69 journald kernelx3 : 0000000000000000 x2 : 0000000100000000
oksbot69 journald kernelx1 : 0000000000000000 x0 : ffff3ccbd505c9c0
oksbot69 journald kernelCall trace:
oksbot69 journald kernel clk_prepare_lock+0x8c/0xa0
oksbot69 journald kernel clk_unprepare+0x30/0x50
oksbot69 journald kernel tegra_spi_runtime_suspend+0x68/0x80 [spi_tegra114]
oksbot69 journald kernel pm_generic_runtime_suspend+0x40/0x60
oksbot69 journald kernel __rpm_callback+0xac/0x1b0
oksbot69 journald kernel rpm_callback+0x38/0xa0
oksbot69 journald kernel rpm_suspend+0xe4/0x650
oksbot69 journald kernel pm_runtime_work+0xd0/0xf0
oksbot69 journald kernel process_one_work+0x1c4/0x4d0
oksbot69 journald kernel worker_thread+0x54/0x430
oksbot69 journald kernel kthread+0x180/0x1b0
oksbot69 journald kernel ret_from_fork+0x10/0x24
oksbot69 journald kernel---[ end trace 0000000000000002 ]---
oksbot69 journald kernelmttcan c310000.mttcan can0: mttcan_poll_ir: some msgs lost on in Q0
