KeyError: 'EXP_PATH' SimulationApp Isaac Sim
I have the following code:
from omni.isaac.kit import SimulationApp
import os
# Set rendering parameters and create an instance of kit
CONFIG = {"renderer": "RayTracedLighting", "headless": False, "width": 1024, "height": 1024, "num_frames": 10}
simulation_app = SimulationApp(launch_config=CONFIG)
Upon selecting Run Selected, I get the following error:
>/tmp/carb.uHGX1y/script_1675179561.py
How should I fix this error?
Screenshot from 2023-01-31 10-40-59
check Omni.replicator.core.scripts.randomizer has no attribute scatter_boxes - #2 by mona.jalal
