Our application does hang when the target hud is enabled which is not a problem because in the GUI you can disable the hud on startup.
Is there a similar (hidden) option for the CLI? I tried loading the project where the target hud is disabled but it starts the application with the hud enabled causing a hang.
Thanks for using Nsight Graphics and sorry you ran into this issue. I’ll find out for you and get back to you as to whether this is possible.
Regards,
The target HUD is controlled by the environment variables NOMAD_TARGET_HUD. However, you have to add NOMAD_TARGET_HUD=0; to the env variables inside the project settings or otherwise ngfx will overwrite it with =1.
