this is leopard team.
as far as we know currently the internal isp do not support usb cam. you need convert the raw data to yuv format manually.
you can reference guvcview code.
thanks
xingxing
We gave up on Leopard Imaging alltogether. Could not get it to work on either Linux or Windows.
We used USB3 cameras from https://www.theimagingsource.com instead. The installation took like 1 minute, and the cameras has also has a blazing fast onboard FPGA that does debayering etc.
are there any updates on this? We have the same problem with our LI-USB30-AR0231-GMSL-R7 Cam. Cannot generate any clear image, neither on Windows nor on Linux or TX2. Is there any sample code LI could provide?
Amazed that Leopard Imaging sells such products without any clear documentation or samples…
