azviran
September 8, 2022, 12:31pm
1
I recently purchased the LI-IMX390-GMSL2 camera from Leopard imaging:
https://www.leopardimaging.com/product/autonomous-camera/maxim-gmsl2-cameras/li-imx390-gmsl2/li-imx390-gmsl2-120h/
I connected it to my Rudi-AGX module (https://connecttech.com/product/rudi-agx-embedded-system-nvidia-jetson-agx-xavier/ ) running Jetpack 4.6.2.
I used the following gstreamer pipeline for streaming the video to the screen:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12’ ! nvegltransform ! nveglglessink sync=0
I tried to measure the latency by capturing a timer on my screen and saw about 120ms delay (3-4 frames @ 30fps).
Is it the minimum possible latency? is there anything I can do to make it better?
Thanks a lot!
Amir
It’s reasonable result. Try higher frame rate should be get improve.
azviran
September 12, 2022, 11:21am
4
ShaneCCC thanks for your reply.
Unfortunately this camera can only output 30fps.
Is there no way to get lower latency?
I saw this post:
that mentioned they can reach as low as 40ms.
Do I need to build special drivers for that?
I also saw this post:
that mentions the queue size may impact the latency.
Thanks,
Amir
The latency is about ~= 4-6 frames times, that’s why suggest using high frame rate sensor mode for it.
azviran
September 13, 2022, 6:48am
6
Thanks ShaneCCC.
Can you tell where this latency is originated from? Is it the camera’s driver or something with the gstreamer?
Are there any cameras that are expected to have a lower latency?
Thanks,
Amir
It’s from the 3A alg and ISP pipeline.
azviran
September 13, 2022, 10:42am
8
Got it, thanks!
Are there any other GMSL cameras you may suggest that have a lower latency in this pipeline?
I would suggest consult with camera partner to check if any high frame rate sensor like 120fps sensor.
system
Closed
October 5, 2022, 5:38am
12
