Hi greivin.fallas,
I work together with ryan5k4rz, the OP, and I am also working on trying to solve this issue.
Thank you for your quick and informative response!
Regarding the use of the ‘argus_camera’ - there is no particular reason for using it other than it is an easy-to-use tool for testing the cameras, with the UI interface allowing for changing certain camera parameters at runtime, and because it’s one of the tools mentioned in the Leopard’s driver installation instructions that should work out of the box.
I tried with GStreamer, first without re-starting the nvargus-daemon. I start Camera 0 (Master) in one console and the live stream works as expected. Streaming Camera 1, for example, in another console works as expected too. However, streaming Camera 3 in another console fails - the GStreamer window freezes before a single frame is displayed. Note that the other streams (Cameras 0 and 1 in this example) continue to stream just fine.
For reference, here is the GStreamer command that I use to launch the stream (with the sensor-id changed for different cameras, of course):
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)2448, height=(int)2058, framerate=20/1' ! nvvidconv flip-method=0 ! 'video/x-raw, format=(string)I420' ! xvimagesink -e
I then followed your suggestion to restart the nvargus-daemon and to relaunch it with the enableCamInfiniteTimeout=1 argument. Unfortunately I am observing the same behavior as described previously - Camera 3 stream window freezes without displaying a single frame. I do see some error messages in the console that is running the nvargus-daemon. Here is the console output:
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[8648]: Connection established (7F8347E1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
=== gst-launch-1.0[8648]: CameraProvider initialized (0x7f7ca98180)CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
=== gst-launch-1.0[8838]: Connection established (7F2F7FE1D0)=== gst-launch-1.0[8838]: CameraProvider initialized (0x7edc000be0)CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
PowerServiceCore:handleRequests: timePassed = 840
=== gst-launch-1.0[8938]: Connection established (7EBAFFD1D0)=== gst-launch-1.0[8938]: CameraProvider initialized (0x7e94000be0)CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
PowerServiceCore:handleRequests: timePassed = 827
Error: waitCsiFrameStart timeout guid 3
VI Stream Id = 3 Virtual Channel = 0
************VI Debug Registers**********
VI_CSIMUX_STAT_FRAME_12 = 0x00000000
VI_CSIMUX_FRAME_STATUS_0 = 0x00000000
VI_CFG_INTERRUPT_STATUS_0 = 0x3f000000
VI_ISPBUFA_ERROR_0 = 0x00000000
VI_FMLITE_ERROR_0 = 0x00000000
VI_NOTIFY_ERROR_0 = 0x00000000
CSI Stream Id = 3 Brick Id = 1
************CSI Debug Registers**********
CILA_INTR_STATUS_CILA[0x20400] = 0x00000000
CILB_INTR_STATUS_CILB[0x20c00] = 0x00000000
INTR_STATUS[0x208a4] = 0x00000000
ERR_INTR_STATUS[0x208ac] = 0x00000000
ERROR_STATUS2VI_VC0[0x20894] = 0x00000000
ERROR_STATUS2VI_VC1[0x20898] = 0x00000000
ERROR_STATUS2VI_VC2[0x2089c] = 0x00000000
ERROR_STATUS2VI_VC3[0x208a0] = 0x00000000
Error: waitCsiFrameEnd timeout guid 3
SCF: Error BadValue: timestamp cannot be 0 (in src/services/capture/NvViCsiHw.cpp, function waitCsiFrameStart(), line 624)
VI_CSIMUX_FRAME_STATUS_0 = 0x00000011
SCF: Error BadValue: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error BadValue: Worker thread ViCsiHw frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error BadValue: timestamp cannot be 0 (in src/services/capture/NvViCsiHw.cpp, function waitCsiFrameEnd(), line 711)
SCF: Error BadValue: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Is there anything here that can point us in the right direction? Or any other logs that would be useful to provide?
Thank you!
