Jetson Xavier • DeepStream Version
6.0 • JetPack Version (valid for Jetson only)
4.4 • TensorRT Version
7.1.3 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs)
questions
my code has tested and passed on dGpu(RTX3090,NvDs 6.0),but when i integrate to the Jetson Xavier, it’s failed,
i found that the deepstream for jetson has removed libnvbufsurface.so and libnvbufsurftransform.so. so how to make gst-dsexample plugin on the jetson platform?
The two libs should be in the directory “/usr/lib/aarch64-linux-gnu/tegra” of Xaiver.
Is DeepStream installed correctly and example can be run correctly?
The version of DeepStream and JetPack seems to be a mismatch. JetPack4.4 works together with DeepStream 5.0, while deepStream 6.0 works with Jetpack 4.6, please double check.
