Linux Nouveau Re-Enable, How!?
I got the driver, tried to install, but it seems to red hat, I’m using Debian 8, how to get back Nouveau without interfir on the configuration prior installed?
What’s the final opinion to get-on or roll back? What about that to Uninstall to on Debian
This depends on how you installed the driver. What did you use, package or .run installer?
Hi, this is run installer, yes! Just got rid off, but getting back after installed driver is important also to know as automation!
the .run installer has the --uninstall option to do that. You should rather use the debian packages from non-free and contrib to install the driver, though.
Great to know that option are described, but for failed Installation it rid-off some settings from Nouveou, even from non-free before start the drive unpack
