Linux NVIDIA Driver fails to shutdown properly
Hello, I’m using a 4070 Laptop GPU with the linux drivers on a dual-boot system (Linux kernel 6.10 and Driver version 555). After shutting down/rebooting normally on linux, on the next reboot of the computer, the nvidia GPU is not detected by the system, both when booting linux and windows.
  • Nvidia-smi gives the error “NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.”
  • On windows the GPU simply does not show up.
It works again after either force shutting down by holding the power key or by shutting down normally on windows. Rebooting on linux does not fix the issue.
Does anyone know what could be causing this issue?
