Release highlights since 440.82:
  • Added support for the following GPUs:
    • A100-PCIE-40GB
    • A100-PG509-200
    • A100-SXM4-40GB
    • GeForce GTX 1650 Ti
    • GeForce GTX 1650 Ti with Max-Q Design
    • GeForce RTX 2060 with Max-Q Design
    • Quadro T1000 with Max-Q Design
  • Added support for Vulkan direct-to-display on DisplayPort displays which are connected via DisplayPort Multi-Stream Transport (DP-MST).
  • Added a new documentation file, supported-gpus.json, which exposes a machine-readable list of supported GPUs and features.
  • Added an implementation of glNamedBufferPageCommitmentARB, which was missing from the NVIDIA driver’s support for the GL_ARB_sparse_buffer extension.
  • Fixed a bug that could cause a KDE Plasma session to crash when running under Wayland.
  • Fixed a bug that could cause some Swap Group configurations to present at half of the display refresh rate.
  • Added a new Connector-N display connector name alias type, with a unique alias assigned to each physical display connector on a GPU. See the README for more information.
  • Fixed a bug that prevented X11 EGL displays from being reinitialized.
  • The 450 driver series is the last that supports NvFBC’s NVFBC_CAPTURE_TO_HW_ENCODER capture interface, which has been deprecated since NVIDIA Capture SDK 6.0 released in 2017. Future NVIDIA drivers after the 450 series will return NVFBC_ERR_UNSUPPORTED if that capture interface is requested. The recommended way to encode captured frames with NVENC is by using the NVIDIA Video Codec SDK.
    See: NVIDIA VIDEO CODEC SDK | NVIDIA Developer
  • Implemented support for NVIDIA NGX. A new library, libnvidia-ngx.so, has been added to support the new functionality. This new library is needed by applications which link against any of the following SDKs:
    • NVIDIA DLSS SDK
    • NVIDIA NGX SDK
  • Fixed a bug which caused Vulkan applications to leak file descriptors when destroying Vulkan instances.
  • Added a fallback presentation path for PRIME Render Offload configurations where the DRI3 and/or Present extension are unavailable.
  • Fixed a bug where vkCreateSampler would fail with no borderColor data, even though it wasn’t needed.
  • Fixed a bug where vkUpdateDescriptorSetWithTemplate would ignore the stride parameter for some VkDescriptorType values.
  • Fixed a bug causing the Plasma desktop panel to freeze when compositing is disabled (353983 – Turning off compositing breaks Plasma panel rendering)
  • Improved Vulkan device enumeration under an X.Org X server environment. See the “Known Issues” in the README for more information.
  • Fixed a visual glitch of Vulkan applications when they stop flipping due to a window change, such as when alt-tab is used to change window focus.
  • Fixed a bug where XGetImage requests would return stale data for flipping Vulkan applications. In particular, this fixes screen-scraping tools such as VNC and import.
  • Removed libnvidia-fatbinaryloader.so from the driver package. This functionality is now built into other driver libraries.
  • Extended the dynamic runtime power management support in the NVIDIA driver to shut off power to video memory under certain conditions. See the chapter titled “PCI-Express Runtime D3 (RTD3) Power Management” in the README for more information.
  • Added HEVC 10/12 bit “decode only” support to the NVIDIA VDPAU driver. Note that VDPAU’s presentation pipeline and OpenGL-VDPAU interop does not support 10- and 12-bit video surfaces yet. See the “VDPAU Support” appendix in the README for supported HEVC decoder profiles.
  • Added support for Image Sharpening for OpenGL and Vulkan applications
  • Added new VdpYCbCrFormats VDP_YCBCR_FORMAT_Y_U_V_444_16, VDP_YCBCR_FORMAT_P010 and VDP_YCBCR_FORMAT_P016 for accessing 16-bit surfaces via VdpVideoSurfaceGetBitsYCbCr() and VdpVideoSurfacePutBitsYCbCr() in the NVIDIA VDPAU driver.
  • Added support to create 16-bit video surfaces in the NVIDIA VDPAU driver.
  • Modified nvidia-persistenced and libnvidia-ml (NVML) to use libtirpc for communication instead of relying on the deprecated glibc RPC implementation.
  • Enabled GPU screens by default on X.Org xserver version 1.20.7 and higher.
  • Fixed a bug where rendering in a separate user namespace (unshare -U) would show black window and produce Xid 13 errors.
  • Removed support for “IgnoreDisplayDevices” X configuration option.
  • Added support for PRIME Synchronization when using displays driven by the x86-video-amdgpu driver as PRIME display offload sinks.
  • Added support for displays connected to NVIDIA GPUs to act as PRIME display offload sinks, also known as “Reverse PRIME”. See the chapter titled “Offloading Graphics Display with RandR 1.4” in the README for additional information.
  • Removed ‘libGL.la’ libtool archive from the install package.
  • Fixed a bug where a Vulkan application under PRIME render offload would not always be correctly throttled to vsync despite the application’s request for VK_PRESENT_MODE_FIFO_KHR. This was particularly prevalent on DXVK titles.
  • Added a workaround for some Pascal based notebooks, where the GPU could fall off the bus when idle.
  • Added new “Connector-N” display device aliases to the X driver’s X configuration option parser. This is useful in conjunction with the “ConnectedMonitor” X configuration option, for emulating the presence of connected monitors without knowing what specific connectors are available. See the “Display Device Names” appendix in the README for details.
  • Disabled OpenGL threaded optimizations by default, as they were causing regressions in some cases. Refer to the README for information on how to enable these optimizations on a per-application basis.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
