I am trying to integrate LoRa sx1278 433MHz Ra-02 with the 40 pin header of the jetson. My goal is to send alerts extracted from a YOLO model via LoRa. However, I am unable to find any guidance for the task on what library should I am supposed to use to interface the device. I have two options, which should I go with? :
Attach the LoRa directly via 40 pin header.
Attach an ESP32 serially, and then attach the LoRa to it, as ESP32 provides easy interfacing via library on the arduino IDE.
To integrate the LoRa SX1278 433MHz Ra-02 module with the Jetson Orin Nano, you have two options:
Option 1: Attach the LoRa directly via 40-pin header
In this approach, you’ll need to connect the LoRa module directly to the 40-pin header on the Jetson Orin Nano. This requires a good understanding of the pinout configuration of both the LoRa module and the Jetson Orin Nano.
Here are the steps to follow:
Pinout configuration: Consult the datasheet of the LoRa SX1278 433MHz Ra-02 module to determine the pinout configuration. Typically, the module has the following pins:
VCC (power supply)
GND (ground)
SCK (clock)
MISO (master in, slave out)
MOSI (master out, slave in)
CS (chip select)
RST (reset)
Jetson Orin Nano pinout: Consult the Technical Reference Manual (TRM) for the Jetson SoC in your developer kit to determine the pinout configuration of the 40-pin header. You’ll need to identify the pins that correspond to the LoRa module’s pins.
Connect the LoRa module: Connect the LoRa module to the 40-pin header on the Jetson Orin Nano, making sure to match the pinout configurations.
Use a library: You’ll need to use a library that supports the LoRa module and the Jetson Orin Nano. Some options include:
libloragw: A C library for LoRaWAN gateways that supports the SX1278 module.
pySX1278: A Python library for the SX1278 module.
Option 2: Attach an ESP32 serially and then attach the LoRa to it
In this approach, you’ll connect the ESP32 board to the Jetson Orin Nano via a serial interface (e.g., UART) and then connect the LoRa module to the ESP32.
Connect the ESP32: Connect the ESP32 board to the Jetson Orin Nano via a serial interface (e.g., UART).
Connect the LoRa module: Connect the LoRa module to the ESP32 board, following the pinout configuration of the ESP32 and the LoRa module.
Use a library: You can use the Arduino IDE to program the ESP32 and interface with the LoRa module using libraries such as:
RadioHead: A library for wireless communication that supports the SX1278 module.
LoRa: A library for LoRaWAN communication that supports the SX1278 module.
Comparison of the two options
Here’s a comparison of the two options:
Option 1 (Direct connection)
Option 2 (ESP32 serial connection)
Complexity
Higher
Lower
Requires knowledge of both LoRa and Jetson Orin Nano pinouts
Only requires knowledge of ESP32 and LoRa pinouts
Library support
Limited library support for direct connection
Wide range of libraries available for ESP32 and LoRa
Ease of use
More challenging due to direct connection
Easier due to serial connection and Arduino IDE support
Based on the comparison, Option 2 (ESP32 serial connection) is recommended if you’re not familiar with the pinout configuration of the LoRa module and the Jetson Orin Nano. This approach provides a more straightforward and easier-to-use solution, with a wide range of libraries available for the ESP32 and LoRa module.
However, if you’re comfortable with the pinout configuration and want a more direct connection, Option 1 (Direct connection) can be a viable solution.
Option 1 is simpler on the hardware side since there is just one connection, LoRa through SPI to the Orin Nano.
Option 2 requires two connections, first going through ESP32 and then to the LoRa. But that may prove to be easier to implement overall with the library on the Arduino.
There are only a couple of other instances on this forum of users mentioning the LoRa SX1278. Only this one seems applicable here: Jetson Nano and LoRa SX1278 setup using SPI (for option 1 with direct connection over SPI).
Hopefully other users can provide comments on what worked for them with LoRa SX1278.
