Low temperature Limit
We are doing the test to operate AGX Orin on low temperature.
I wonder is there any shutdown event for low temperature as same as high temperature
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/PlatformPowerAndPerformance/JetsonOrinNanoSeriesJetsonOrinNxSeriesAndJetsonAgxOrinSeries.html?highlight=thermal#thermal-specifications
If the temperature is too low, it will not boot the device to kernel and userspace. Will shutdown in bootloader stage.
On Jetpack 5.1.1, there is a known issue that the system cannot boot in -20C. We have a fix for it. Please check
Jetson/L4T/r35.3.x patches - eLinux.org
[thermal] boot failure in low temperature environment for Orin series
