https://forums.developer.nvidia.com/t/jetson-orin-200t-module-s-minimum-operating-temperature-is-only-20/241413
请问这个话题中的解决方法使用于R35.1吗,我使用Jetson AGX Orin 32G module、 Jetson Linux 35.1存在同样的问题,但是我看35.1下的 Additional Files 没有对应的补丁?
WayneWWW
2
Please upgrade the BSP.
Related topics
| Jetson Linux 35.2.1 orin 模组低温启动异常问题 | 2 | 154 | October 16, 2024 | |
| The ubuntu system cannot start at -25 ° C | 2 | 469 | July 19, 2023 | |
| Orin boot up failed in low temperature | 3 | 177 | July 4, 2024 | |
| After flash, agx running exception | 6 | 132 | September 18, 2024 | |
| Issue in Cold boot at -25C for Jetson AGX Orin with L4T35.2.1 | 1 | 525 | September 20, 2023 | |
| AGX Orin cannot be powered on at 55 ° C | 10 | 295 | August 13, 2024 | |
| Orin AGX Industrial fails to boot at low temperature | 4 | 476 | April 12, 2024 | |
| Jetson AGX Orin Cold Boot Issue | 2 | 931 | August 10, 2023 | |
| Orin Industrial low temp operation | 17 | 1379 | October 12, 2023 | |
| Jetson Orin 200T module’s minimum operating temperature is only -20℃ | 56 | 4968 | May 27, 2023 |
