Testing in high and low temperature environments
Dears,
The Orin NX was tested at temperature 50 ° or -25 ° environmental, but the equipment malfunctioned. Does Orin NX support testing in such environments?
No sure which JetPack SW you’re using for the test.
We had the low temperature reboot failed issue at JetPack 5.1.1, and fixed at JetPack 5.1.2.
You can find the patch for JetPack 5.1.1 at Jetson Linux 35.3.1 | NVIDIA Developer
I will try this version Jetpack 5.1.2.
