How can I get my LTE Dongle to work on the Jetson TK1. Ethernet is working but there is no internet once I use the dongle. I also installed the linux-firmware package without success.
The dongle is a ZTE MF283.
Any help would be appreciated. Thanks in advance.
With a quick googling I found this: http://www.g7smy.co.uk/?p=505
So, does “lsusb” show your device? If so, what “mode” does it show?
If the mode is wrong, you may try:
sudo apt-get install usb-modeswitch sudo usb_modeswitch -v 0x19d2 -p 0x1405 -d
The USB CDC ethernet seems to be already enabled in the default Jetson kernel.
