Lula and dofbot errors
I was running this code
from pinocchio.robot_wrapper import RobotWrapper
import pinocchio as pin
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless": False})
from fr3_usd import Franka
from omni.isaac.core import World
from omni.isaac.core import SimulationContext
from omni.isaac.core.objects import VisualCuboid
from omni.isaac.dynamic_control import _dynamic_control
import numpy as np
def main():
    world = World(stage_units_in_meters=1.0, physics_dt=1 / 1000)
    world.scene.add_default_ground_plane()
    simulation_context = SimulationContext()
    # Create pin_robot
    package_directory = "/home/mocap/Documents/FR3Env/FR3Env"
    urdf_path = "/home/mocap/Documents/FR3Env/FR3Env/robots/fr3.urdf"
    robot = RobotWrapper.BuildFromURDF(urdf_path, package_directory)
    # Load USD of Franka
    asset_path = "/home/mocap/Documents/DiffOptIsaac/robots/fr3.usda"
    fr3_robot = world.scene.add(
        Franka(
            prim_path="/World/Fancy_Franka", name="fancy_franka", usd_path=asset_path
    fancy_cube = world.scene.add(
        VisualCuboid(
            prim_path="/World/random_cube",
            name="fancy_cube",
            position=np.array([0.4, 0.3, 0.5]),
            scale=np.array([0.01, 0.01, 0.01]),
            color=np.array([1.0, 0, 0.0]),
    world.reset()
    fr3_robot.enable_gravity()
    dc = _dynamic_control.acquire_dynamic_control_interface()
    articulation = dc.get_articulation("/World/Fancy_Franka")
    dc.wake_up_articulation(articulation)
    q_init = np.array(
            0.0,
            -0.785398163,
            0.0,
            -2.35619449,
            0.0,
            1.57079632679,
            0.785398163397,
            0.0,
            0.0,
    fr3_robot.set_joint_positions(q_init)
    tcp_frame_id = robot.model.getFrameId("fr3_hand_tcp")
    jacobian_frame = pin.ReferenceFrame.LOCAL_WORLD_ALIGNED
    p_des = np.array([0.4, 0.3, 0.5])
    while simulation_app.is_running():
        q = fr3_robot.get_joint_positions()
        dq = fr3_robot.get_joint_velocities()
        t = simulation_context.current_time
        robot.computeJointJacobians(q)
        robot.framesForwardKinematics(q)
        robot.centroidalMomentum(q, dq)
        G = fr3_robot._articulation_view.get_generalized_gravity_forces()
        p = robot.data.oMf[tcp_frame_id].translation
        J = robot.getFrameJacobian(tcp_frame_id, jacobian_frame)
        p_error = p_des - p
        v = J[:3, :] @ dq
        tau = J[:3, :].T @ (5.0 * p_error - 5.0 * v) - 1.0 * dq + G
        dc.set_articulation_dof_efforts(articulation, tau.flatten().tolist())
        world.step(render=True)
    simulation_app.close()
if __name__ == "__main__":
    main()
And I get issues like
[omni.ext.plugin] [ext: omni.isaac.universal_robots-0.3.2] Failed to startup python extension.
[Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.dofbot. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs.
[Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.dofbot' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot' failed to load.
The output is
Starting kit application with the following args:  ['/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts', '--ext-folder', '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/apps', '--/physics/cudaDevice=0', '--portable']
Passing the following args to the base kit application:  []
[Info] [carb] Logging to file: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/logs/Kit/Isaac-Sim/2023.1/kit_20231020_173337.log
2023-10-20 21:33:37 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.054s] [ext: omni.kit.async_engine-0.0.0] startup
[0.401s] [ext: omni.activity.core-1.0.1] startup
[0.404s] [ext: omni.assets.plugins-0.0.0] startup
[0.405s] [ext: omni.stats-0.0.0] startup
[0.406s] [ext: omni.client-1.0.1] startup
[0.412s] [ext: omni.activity.profiler-1.0.2] startup
[0.414s] [ext: omni.gpu_foundation-0.0.0] startup
[0.422s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.423s] [ext: carb.windowing.plugins-1.0.0] startup
[0.524s] [ext: omni.kit.renderer.init-0.0.0] startup
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
2023-10-20 21:33:37 [726ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RKL GT1)
| Driver Version: 520.61.05     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 2080 Ti       | Yes: 0 |     | 11510   MB | 10de      | 0          |
|     |                                  |        |     |            | 1e04      | 1f0bed54.. |
|     |                                  |        |     |            | 1         |            |
| 1   | Intel(R) Graphics (RKL GT1)      |        |     | 23863   MB | 8086      | 0          |
|     |                                  |        |     |            | 4c8a      | e6537608.. |
|     |                                  |        |     |            | 0         |            |
| OS: 20.04.6 LTS (Focal Fossa) ubuntu, Version: 20.04.6, Kernel: 5.15.0-83-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: 11th Gen Intel(R) Core(TM) i7-11700 @ 2.50GHz | Cores: 8 | Logical: 16
| Total Memory (MB): 31817 | Free Memory: 27219
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[1.169s] [ext: omni.kit.pipapi-0.0.0] startup
[1.170s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.171s] [ext: omni.pip.compute-1.2.0] startup
[1.171s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[1.210s] [ext: omni.pip.cloud-1.0.1] startup
[1.211s] [ext: omni.isaac.core_archive-2.2.1] startup
[1.212s] [ext: omni.kit.loop-isaac-1.0.2] startup
[1.212s] [ext: omni.kit.test-0.0.0] startup
[1.213s] [ext: omni.kit.telemetry-0.4.0] startup
[1.231s] [ext: omni.isaac.ml_archive-1.1.3] startup
[1.231s] [ext: omni.mtlx-0.1.0] startup
[1.232s] [ext: omni.usd.config-1.0.3] startup
[1.238s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.238s] [ext: omni.usd.libs-1.0.0] startup
[1.406s] [ext: omni.appwindow-1.1.5] startup
[1.812s] [ext: omni.kit.renderer.core-0.0.0] startup
[3.043s] [ext: omni.kit.renderer.capture-0.0.0] startup
[3.045s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[3.122s] [ext: carb.audio-0.1.0] startup
[3.145s] [ext: omni.ui-2.17.3] startup
[3.168s] [ext: omni.uiaudio-1.0.0] startup
[3.170s] [ext: omni.kit.mainwindow-1.0.0] startup
[3.171s] [ext: omni.kit.uiapp-0.0.0] startup
[3.171s] [ext: omni.usd.schema.anim-0.0.0] startup
[3.368s] [ext: omni.usd.schema.physics-0.0.0] startup
[3.391s] [ext: omni.usd.schema.semantics-0.0.0] startup
[3.394s] [ext: omni.usd.schema.isaac-2.0.1] startup
[3.403s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[3.408s] [ext: omni.usd.schema.physx-0.0.0] startup
[3.443s] [ext: omni.usd.schema.audio-0.0.0] startup
[3.447s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[3.454s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[3.455s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[3.458s] [ext: omni.anim.navigation.schema-105.1.0] startup
[3.462s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[3.469s] [ext: omni.kit.window.popup_dialog-2.0.22] startup
[3.474s] [ext: omni.usd_resolver-1.0.0] startup
[3.479s] [ext: omni.kit.widget.nucleus_connector-1.1.1] startup
[3.481s] [ext: omni.graph.exec-0.2.7] startup
[3.482s] [ext: omni.resourcemonitor-105.0.0] startup
[3.484s] [ext: omni.usd.core-1.1.6] startup
[3.488s] [ext: omni.kit.actions.core-1.0.0] startup
[3.490s] [ext: omni.timeline-1.0.9] startup
[3.492s] [ext: omni.kit.exec.core-0.4.1] startup
[3.494s] [ext: omni.ui.scene-1.6.14] startup
[3.500s] [ext: omni.hydra.usdrt_delegate-7.2.23] startup
[3.516s] [ext: omni.kit.commands-1.4.6] startup
[3.519s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[3.521s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[3.529s] [ext: omni.kit.widget.versioning-1.4.4] startup
[3.531s] [ext: omni.usd-1.10.15] startup
[3.592s] [ext: omni.kit.menu.utils-1.5.4] startup
[3.602s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[3.624s] [ext: omni.kit.widget.nucleus_info-1.0.1] startup
[3.625s] [ext: omni.kit.widget.filebrowser-2.3.34] startup
[3.630s] [ext: omni.kit.search_core-1.0.4] startup
[3.630s] [ext: omni.kit.widget.path_field-2.0.7] startup
[3.631s] [ext: omni.kit.notification_manager-1.0.6] startup
[3.633s] [ext: omni.kit.widget.search_delegate-1.0.3] startup
[3.634s] [ext: omni.kit.widget.browser_bar-2.0.8] startup
[3.634s] [ext: omni.kit.clipboard-1.0.3] startup
[3.635s] [ext: omni.kit.usd.layers-2.1.19] startup
[3.646s] [ext: omni.kit.window.filepicker-2.10.3] startup
[3.657s] [ext: omni.kit.menu.create-1.0.11] startup
[3.659s] [ext: omni.kit.window.file_importer-1.0.21] startup
[3.662s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[3.663s] [ext: omni.kit.primitive.mesh-1.0.14] startup
[3.666s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[3.667s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[3.671s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[3.672s] [ext: omni.kit.stage_templates-1.1.20] startup
[3.674s] [ext: omni.kit.widget.filter-1.1.2] startup
[3.675s] [ext: omni.kit.context_menu-1.6.6] startup
[3.676s] [ext: omni.kit.window.file-1.3.41] startup
[3.679s] [ext: omni.kit.widget.stage-2.9.2] startup
[3.690s] [ext: omni.kit.collaboration.presence_layer-1.0.7] startup
[3.692s] [ext: omni.kit.widget.searchfield-1.1.2] startup
[3.694s] [ext: omni.kit.window.drop_support-1.0.1] startup
[3.695s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[3.695s] [ext: omni.kit.widget.prompt-1.0.5] startup
[3.696s] [ext: omni.kit.window.property-1.9.6] startup
[3.699s] [ext: omni.kit.window.content_browser-2.7.14] startup
[3.710s] [ext: omni.kit.widget.live_session_management-1.2.16] startup
[3.714s] [ext: omni.kit.property.usd-3.21.12] startup
[3.723s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[3.725s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[3.726s] [ext: omni.ui_query-1.1.1] startup
[3.726s] [ext: omni.kit.widget.settings-1.0.4] startup
[3.727s] [ext: omni.kit.ui_test-1.2.13] startup
[3.729s] [ext: omni.kit.window.preferences-1.3.21] startup
[3.733s] [ext: omni.kvdb-0.0.0] startup
[3.735s] [ext: omni.convexdecomposition-105.1.9-5.1] startup
[3.740s] [ext: omni.inspect-1.0.1] startup
[3.742s] [ext: omni.localcache-0.0.0] startup
[3.744s] [ext: omni.physx.foundation-105.1.9-5.1] startup
[3.744s] [ext: omni.usdphysics-105.1.9-5.1] startup
[3.748s] [ext: omni.graph.tools-1.41.3] startup
[3.766s] [ext: omni.graph.core-2.139.8] startup
[3.770s] [ext: omni.iray.libs-0.0.0] startup
[3.774s] [ext: usdrt.scenegraph-7.2.23] startup
[3.823s] [ext: omni.physx.cooking-105.1.9-5.1] startup
[3.832s] [ext: omni.volume-0.3.0] startup
[3.840s] [ext: omni.mdl.neuraylib-0.2.0] startup
[3.841s] [ext: omni.physx-105.1.9-5.1] startup
2023-10-20 21:33:40 [3,844ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[3.856s] [ext: omni.kit.numpy.common-0.1.2] startup
[3.857s] [ext: omni.hydra.rtx-0.1.0] startup
[3.869s] [ext: omni.hydra.pxr-1.1.4] startup
[3.875s] [ext: omni.isaac.dynamic_control-1.2.5] startup
[3.884s] [ext: omni.kit.hydra_texture-1.1.10] startup
[3.890s] [ext: omni.mdl-0.1.2] startup
[3.909s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[3.914s] [ext: omni.kit.viewport.registry-104.0.4] startup
[3.915s] [ext: omni.kit.widget.viewport-105.1.4] startup
[3.919s] [ext: omni.kit.material.library-1.3.39] startup
[3.926s] [ext: omni.hydra.engine.stats-1.0.1] startup
[3.931s] [ext: omni.kit.manipulator.viewport-104.0.8] startup
[3.932s] [ext: omni.kit.viewport.window-105.1.9] startup
[3.953s] [ext: omni.physics.tensors-0.1.0] startup
[3.960s] [ext: omni.kit.widget.graph-1.8.4] startup
[3.966s] [ext: omni.kit.usd_undo-0.1.2] startup
[3.966s] [ext: omni.kit.viewport.utility-1.0.16] startup
[3.967s] [ext: omni.physx.tensors-0.1.0] startup
[3.974s] [ext: omni.kit.window.extensions-1.3.0] startup
[3.980s] [ext: omni.graph-1.106.0] startup
[4.027s] [ext: omni.debugdraw-0.1.2] startup
[4.033s] [ext: omni.warp.core-0.10.1] startup
Warp 0.10.1 initialized:
   CUDA Toolkit: 11.5, Driver: 11.8
   Devices:
     "cpu"    | x86_64
     "cuda:0" | NVIDIA GeForce RTX 2080 Ti (sm_75)
   Kernel cache: /home/mocap/.cache/warp/0.10.1
[4.176s] [ext: omni.isaac.version-1.0.3] startup
[4.178s] [ext: omni.graph.ui-1.48.0] startup
[4.200s] [ext: omni.isaac.core-2.10.2] startup
[5.622s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[5.641s] [ext: omni.graph.action-1.55.0] startup
2023-10-20 21:33:42 [5,634ms] [Warning] [carb] [Plugin: libomni.graph.action.plugin.so] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph.action/bin/libomni.graph.action.plugin.so remained loaded after unload request
[5.687s] [ext: omni.isaac.ui-0.13.2] startup
[5.698s] [ext: omni.isaac.cloner-0.7.0] startup
[5.700s] [ext: omni.isaac.utils-0.5.3] startup
[5.717s] [ext: omni.isaac.gym-0.8.5] startup
[5.720s] [ext: omni.isaac.debug_draw-0.6.0] startup
2023-10-20 21:33:42 [5,718ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[5.735s] [ext: omni.importer.mjcf-1.1.0] startup
[5.747s] [ext: omni.isaac.mjcf-1.0.0] startup
2023-10-20 21:33:42 [5,736ms] [Warning] [omni.isaac.mjcf] The extension omni.isaac.mjcf has been deprecated. Please use omni.importer.mjcf instead.
[5.748s] [ext: omni.isaac.occupancy_map-0.3.1] startup
[5.778s] [ext: omni.importer.urdf-1.1.3] startup
[5.829s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[5.831s] [ext: omni.kit.graph.delegate.default-1.1.1] startup
[5.833s] [ext: omni.kit.graph.usd.commands-1.3.0] startup
[5.834s] [ext: omni.kit.browser.core-2.3.9] startup
[5.840s] [ext: omni.kit.widget.spinner-1.0.5] startup
[5.842s] [ext: omni.kit.window.cursor-1.1.1] startup
[5.843s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[5.846s] [ext: omni.graph.image.core-0.1.0] startup
[5.848s] [ext: omni.kit.browser.folder.core-1.9.7] startup
[5.853s] [ext: omni.graph.nodes-1.106.3] startup
[6.057s] [ext: omni.kit.viewport.menubar.core-105.0.17] startup
[6.089s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[6.095s] [ext: omni.kit.graph.delegate.modern-1.9.0] startup
[6.102s] [ext: omni.kit.browser.sample-1.4.6] startup
[6.110s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[6.116s] [ext: omni.syntheticdata-0.4.10] startup
[6.155s] [ext: omni.graph.window.core-1.84.0] startup
[6.173s] [ext: omni.warp-0.10.1] startup
[6.657s] [ext: omni.kit.window.material_graph-1.8.9] startup
[6.678s] [ext: omni.graph.scriptnode-1.1.6] startup
[6.687s] [ext: omni.command.usd-1.0.2] startup
[6.689s] [ext: omni.graph.window.action-1.11.2] startup
[6.697s] [ext: omni.replicator.core-1.10.10] startup
2023-10-20 21:33:43 [6,783ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[6.967s] [ext: omni.activity.pump-1.0.0] startup
[6.969s] [ext: omni.isaac.core_nodes-1.6.1] startup
[7.005s] [ext: omni.kit.actions.window-1.1.0] startup
[7.009s] [ext: omni.kit.viewport.ready-1.0.5] startup
[7.011s] [ext: omni.isaac.wheeled_robots-0.7.2] startup
[7.035s] [ext: omni.kit.selection-0.1.2] startup
[7.038s] [ext: omni.kit.hotkeys.window-1.4.0] startup
[7.044s] [ext: omni.isaac.kit-1.4.5] startup
[7.045s] [ext: omni.kit.widget.stage_icons-1.0.3] startup
[7.046s] [ext: omni.kit.menu.edit-1.1.13] startup
[7.050s] [ext: omni.kit.widget.layers-1.6.28] startup
[7.063s] [ext: omni.kit.menu.file-1.1.7] startup
[7.066s] [ext: omni.kit.window.stage-2.4.0] startup
[7.071s] [ext: omni.sensors.nv.common-0.0.2-isaacsim.3] startup
[7.081s] [ext: omni.kit.property.layer-1.1.4] startup
[7.085s] [ext: omni.sensors.nv.materials-0.1.1-isaacsim.3] startup
[7.087s] [ext: omni.kit.menu.stage-1.2.3] startup
[7.089s] [ext: omni.sensors.nv.wpm-0.1.2-isaacsim.3] startup
[7.090s] [ext: omni.kit.property.audio-1.0.9] startup
[7.096s] [ext: omni.sensors.nv.lidar-0.1.4-isaacsim.3] startup
[7.103s] [ext: omni.isaac.range_sensor-2.0.0] startup
[7.163s] [ext: omni.isaac.lula-2.1.0] startup
2023-10-20 21:33:44 [7,160ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.lula. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py/omni/ext/_impl/custom_importer.py", line 76, in import_module
    return importlib.import_module(name)
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/python/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/omni/isaac/lula/__init__.py", line 10, in <module>
    from .extension import *
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/omni/isaac/lula/extension.py", line 24, in <module>
    from lula import LogLevel, set_default_logger_prefix, set_log_level
ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
2023-10-20 21:33:44 [7,160ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.lula' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula' failed to load.
At:
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py/omni/ext/_impl/_internal.py(213): startup
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py/omni/ext/_impl/_internal.py(328): startup_extension
  PythonExtension.cpp::startup()(2): <module>
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py(303): _start_app
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py(192): __init__
  /home/mocap/Documents/DiffOptIsaac/impedance_control_new.py(5): <module>
2023-10-20 21:33:44 [7,160ms] [Error] [omni.ext.plugin] [ext: omni.isaac.lula-2.1.0] Failed to startup python extension.
[7.706s] [ext: omni.sensors.nv.radar-0.1.1-isaacsim.3] startup
[7.712s] [ext: omni.isaac.surface_gripper-0.5.0] startup
[7.728s] [ext: omni.kit.property.geometry-1.2.10] startup
[7.733s] [ext: omni.kit.property.camera-1.0.5] startup
[7.736s] [ext: omni.isaac.sensor-9.9.1] startup
[7.825s] [ext: omni.isaac.motion_generation-5.1.1] startup
2023-10-20 21:33:44 [7,824ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.motion_generation. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/__init__.py", line 14, in <module>
    from omni.isaac.motion_generation.lula.kinematics import LulaKinematicsSolver
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/lula/__init__.py", line 9, in <module>
    from .kinematics import LulaKinematicsSolver
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/lula/kinematics.py", line 12, in <module>
    import lula
2023-10-20 21:33:44 [7,824ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.motion_generation' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation' failed to load.
At:
2023-10-20 21:33:44 [7,824ms] [Error] [omni.ext.plugin] [ext: omni.isaac.motion_generation-5.1.1] Failed to startup python extension.
[8.111s] [ext: omni.isaac.manipulators-1.1.0] startup
[8.118s] [ext: omni.hydra.scene_api-0.1.2] startup
[8.129s] [ext: omni.kit.property.material-1.8.30] startup
[8.134s] [ext: omni.kit.property.light-1.0.8] startup
[8.137s] [ext: omni.isaac.franka-0.4.0] startup
2023-10-20 21:33:45 [8,135ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.franka. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.franka/omni/isaac/franka/__init__.py", line 10, in <module>
    from omni.isaac.franka.kinematics_solver import KinematicsSolver
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.franka/omni/isaac/franka/kinematics_solver.py", line 11, in <module>
    import omni.isaac.motion_generation.interface_config_loader as interface_config_loader
    import lula
2023-10-20 21:33:45 [8,135ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.franka' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.franka' failed to load.
At:
2023-10-20 21:33:45 [8,135ms] [Error] [omni.ext.plugin] [ext: omni.isaac.franka-0.4.0] Failed to startup python extension.
2023-10-20 21:33:45 [8,415ms] [Error] [omni.ext.python] ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
At:
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/lula/kinematics.py(12): <module>
  <frozen importlib._bootstrap>(241): _call_with_frames_removed
  <frozen importlib._bootstrap_external>(883): exec_module
  <frozen importlib._bootstrap>(703): _load_unlocked
  <frozen importlib._bootstrap>(1006): _find_and_load_unlocked
  <frozen importlib._bootstrap>(1027): _find_and_load
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/lula/__init__.py(9): <module>
  <frozen importlib._bootstrap>(992): _find_and_load_unlocked
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/__init__.py(14): <module>
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.franka/omni/isaac/franka/kinematics_solver.py(11): <module>
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.franka/omni/isaac/franka/__init__.py(10): <module>
  <frozen importlib._bootstrap>(1050): _gcd_import
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/python/lib/python3.10/importlib/__init__.py(126): import_module
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph/omni/graph/core/_impl/_registration/extension_management.py(154): extension_management_factory
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph/omni/graph/core/_impl/_registration/register_python_ogn.py(70): register_python_ogn
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py/carb/profiler/__init__.py(85): wrapper
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph/omni/graph/core/_impl/registration.py(34): __init__
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph/omni/graph/core/_impl/extension.py(120): on_after_ext_enabled
[8.427s] [ext: omni.kit.property.skel-1.0.4] startup
[8.431s] [ext: omni.kit.property.transform-1.3.10] startup
[8.436s] [ext: omni.kit.property.render-1.1.1] startup
[8.438s] [ext: omni.kit.profiler.window-2.1.2] startup
2023-10-20 21:33:45 [8,535ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
[8.553s] [ext: omni.kit.property.isaac-0.2.1] startup
[8.557s] [ext: omni.kit.property.bundle-1.2.9] startup
[8.560s] [ext: omni.isaac.quadruped-1.3.2] startup
[8.576s] [ext: omni.isaac.cortex-0.3.5] startup
[8.580s] [ext: omni.kit.viewport.actions-105.0.10] startup
[8.585s] [ext: omni.kit.stage_column.payload-1.0.10] startup
[8.588s] [ext: omni.kit.stage_column.variant-1.0.12] startup
[8.591s] [ext: omni.isaac.scene_blox-0.1.0] startup
[8.594s] [ext: omni.isaac.cortex.sample_behaviors-1.0.4] startup
[8.598s] [ext: omni.kit.viewport.menubar.display-105.0.2] startup
[8.601s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[8.610s] [ext: omni.kit.manipulator.transform-104.6.14] startup
[8.613s] [ext: omni.usdphysics.ui-105.1.9-5.1] startup
[8.653s] [ext: omni.physx.commands-105.1.9-5.1] startup
[8.657s] [ext: omni.kit.manipulator.tool.snap-1.3.1] startup
[8.666s] [ext: omni.kit.viewport.menubar.camera-105.1.6] startup
[8.673s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[8.675s] [ext: omni.physx.ui-105.1.9-5.1] startup
[8.712s] [ext: usdrt.gf-1.0.2] startup
[8.712s] [ext: omni.kit.viewport.menubar.render-105.1.0] startup
[8.715s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[8.721s] [ext: omni.kit.manipulator.selection-104.0.7] startup
[8.723s] [ext: omni.kit.manipulator.prim-105.0.9] startup
[8.731s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[8.735s] [ext: omni.physx.demos-105.1.9-5.1] startup
[8.740s] [ext: omni.kit.property.physx-0.1.0] startup
[8.843s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[8.844s] [ext: omni.isaac.universal_robots-0.3.2] startup
2023-10-20 21:33:45 [8,847ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.universal_robots. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/__init__.py", line 9, in <module>
    from omni.isaac.universal_robots.kinematics_solver import KinematicsSolver
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/kinematics_solver.py", line 15, in <module>
    import lula
2023-10-20 21:33:45 [8,847ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.universal_robots' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.universal_robots' failed to load.
At:
2023-10-20 21:33:45 [8,847ms] [Error] [omni.ext.plugin] [ext: omni.isaac.universal_robots-0.3.2] Failed to startup python extension.
2023-10-20 21:33:46 [9,160ms] [Error] [omni.ext.python] ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
At:
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/kinematics_solver.py(15): <module>
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/__init__.py(9): <module>
[9.172s] [ext: omni.physx.camera-105.1.9-5.1] startup
[9.183s] [ext: omni.kit.window.toolbar-1.5.3] startup
[9.187s] [ext: omni.physx.cct-105.1.9-5.1] startup
[9.207s] [ext: omni.rtx.window.settings-0.6.9] startup
[9.215s] [ext: omni.physx.graph-105.1.9-5.1] startup
[9.231s] [ext: omni.kit.widget.live-2.1.3] startup
[9.234s] [ext: omni.physx.supportui-105.1.9-5.1] startup
[9.254s] [ext: omni.physx.vehicle-105.1.9-5.1] startup
[9.272s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[9.272s] [ext: omni.graph.ui_nodes-1.5.10] startup
[9.314s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
[9.318s] [ext: omni.kit.window.commands-0.2.4] startup
[9.321s] [ext: omni.kit.window.console-0.2.9] startup
[9.335s] [ext: omni.physx.bundle-105.1.9-5.1] startup
[9.335s] [ext: omni.kit.window.script_editor-1.7.4] startup
[9.339s] [ext: omni.graph.bundle.action-2.0.4] startup
[9.339s] [ext: omni.kit.menu.common-1.1.4] startup
[9.342s] [ext: omni.kit.window.status_bar-0.1.6] startup
[9.348s] [ext: omni.kit.window.title-1.1.3] startup
[9.350s] [ext: omni.replicator.composer-1.2.17] startup
[9.376s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[9.379s] [ext: omni.replicator.isaac-1.10.1] startup
[9.414s] [ext: omni.replicator.replicator_yaml-2.0.4] startup
[9.428s] [ext: omni.rtx.settings.core-0.5.11] startup
[9.435s] [ext: omni.kit.viewport.menubar.lighting-105.0.5] startup
[9.439s] [ext: semantics.schema.editor-0.3.4] startup
[9.443s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[9.443s] [ext: omni.isaac.urdf-1.0.0] startup
2023-10-20 21:33:46 [9,431ms] [Warning] [omni.isaac.urdf] The extension omni.isaac.urdf has been deprecated. Please use omni.importer.urdf instead.
[9.443s] [ext: omni.isaac.dofbot-0.3.0] startup
2023-10-20 21:33:46 [9,441ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.dofbot. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot/omni/isaac/dofbot/__init__.py", line 10, in <module>
    from omni.isaac.dofbot.kinematics_solver import KinematicsSolver
  File "/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot/omni/isaac/dofbot/kinematics_solver.py", line 11, in <module>
    import lula
2023-10-20 21:33:46 [9,441ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.dofbot' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot' failed to load.
At:
2023-10-20 21:33:46 [9,441ms] [Error] [omni.ext.plugin] [ext: omni.isaac.dofbot-0.3.0] Failed to startup python extension.
2023-10-20 21:33:46 [9,773ms] [Error] [omni.ext.python] ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
At:
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot/omni/isaac/dofbot/kinematics_solver.py(11): <module>
  /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot/omni/isaac/dofbot/__init__.py(10): <module>
[9.785s] [ext: omni.graph.window.generic-1.9.3] startup
[9.794s] [ext: omni.kit.window.stats-0.1.4] startup
[9.796s] [ext: omni.isaac.sim.python-2023.1.0] startup
[9.798s] Simulation App Starting
2023-10-20 21:33:49 [12,519ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2023-10-20 21:33:49 [12,520ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[12.609s] app ready
2023-10-20 21:33:50 [13,311ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2023-10-20 21:33:50 [13,311ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[13.556s] RTX ready
[14.010s] Simulation App Startup Complete
2023-10-20 21:33:53 [16,374ms] [Warning] [omni.physx.plugin] The rigid body at /World/Fancy_Franka/fr3_hand_tcp has a possibly invalid inertia tensor of {1.0, 1.0, 1.0} and a negative mass, small sphere approximated inertia was used. Either specify correct values in the mass properties, or add collider(s) to any shape(s) that you wish to automatically compute mass properties for.
2023-10-20 21:33:53 [16,374ms] [Warning] [omni.physx.plugin] The rigid body at /World/Fancy_Franka/fr3_link8 has a possibly invalid inertia tensor of {1.0, 1.0, 1.0} and a negative mass, small sphere approximated inertia was used. Either specify correct values in the mass properties, or add collider(s) to any shape(s) that you wish to automatically compute mass properties for.
2023-10-20 21:33:53 [16,374ms] [Warning] [omni.physx.plugin] Detected an articulation at /World/Fancy_Franka with more than 4 velocity iterations being added to a TGS scene.The related behavior changed recently, please consult the changelog. This warning will only print once.
[29.567s] Simulation App Shutting Down
2023-10-20 21:34:06 [29,568ms] [Warning] [carb] [Plugin: omni.spectree.delegate.plugin] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.usd_resolver/bin/libomni.spectree.delegate.plugin.so remained loaded after unload request
2023-10-20 21:34:06 [29,597ms] [Warning] [omni.core.ITypeFactory] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph.action/bin/libomni.graph.action.plugin.so remained loaded after unload request.
2023-10-20 21:34:06 [29,598ms] [Warning] [omni.core.ITypeFactory] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.activity.core/bin/libomni.activity.core.plugin.so remained loaded after unload request.
If someone can help me understand what might be the issue that would be greatly appreciated.
Thanks in advance!
Hi bolun,
I attempted a repro by:
  1. Installing pinnochio using ./python.sh -m pip install pin
  2. Cloning your FR3 repo (GitHub - BolunDai0216/FR3Env)
  3. Paring down your script to a more minimal form that doesn’t require the fr3_usd lib.
This is the script I ran:
def main():
    # Create pin_robot
    package_directory = "/home/bryan/Downloads/temp/FR3Env/FR3Env"
    urdf_path = "/home/bryan/Downloads/temp/FR3Env/FR3Env/robots/fr3.urdf"
    main()
This script was able to load the pinnochio robot with no issues.
Note, these tests were carried out in Isaac Sim 2023.1.0
@bpeele Thanks for the response!
Sorry for the confusion. Using the code I provided in this thread, I was also able to load the pinocchio robot. However, there were many errors in the command line output (which did not stop the execution). If you can help me understand how to resolve the errors that would be great!
I did create a separate thread where I mentioned the issue of not being able to load pinocchio robot and a URDF simultaneously (Segmentation Fault after creating Pinocchio robot). I would also appreciate it if you could take a look at that thread!
With my simplified version of your script, I am not able to reproduce your errors on a clean build of Isaac Sim 2023.1.0
If you have a script I can run that reproduces your error on a clean download of Isaac Sim 2023.1.0, I can attempt to dig deeper.
Specifically, I would be interested to see if you can provide a script that reproduces the errors without needing to import this custom library: from fr3_usd import Franka
@bpeele I updated the code to remove from fr3_usd import Franka. The code I am running is:
from omni.importer.urdf import _urdf
import omni.kit.commands
from omni.isaac.core.utils.types import ArticulationAction
from omni.isaac.franka import Franka
import numpy as np
# Create pin_robot
# Set the settings in the import config
import_config = _urdf.ImportConfig()
import_config.merge_fixed_joints = False
import_config.convex_decomp = False
import_config.import_inertia_tensor = True
import_config.fix_base = True
import_config.make_default_prim = True
import_config.self_collision = False
import_config.create_physics_scene = True
import_config.import_inertia_tensor = False
import_config.default_drive_strength = 1047.19751
import_config.default_position_drive_damping = 52.35988
import_config.default_drive_type = _urdf.UrdfJointTargetType.JOINT_DRIVE_POSITION
import_config.distance_scale = 1
import_config.density = 0.0
# Get the urdf file path
extension_path = get_extension_path_from_name("omni.importer.urdf")
root_path = extension_path + "/data/urdf/robots/franka_description/robots"
file_name = "panda_arm_hand.urdf"
# Finally import the robot
result, prim_path = omni.kit.commands.execute("URDFParseAndImportFile", urdf_path="{}/{}".format(root_path, file_name), import_config=import_config,)
franka = world.scene.add(Franka(prim_path=prim_path, name="fancy_franka"))
world.reset()
franka.disable_gravity()
articulation_controller = franka.get_articulation_controller()
articulation_controller.set_effort_modes("force")
articulation_controller.switch_control_mode("effort")
q_des = np.array(
        np.pi / 4,
        -0.785398163,
        0.0,
        -2.35619449,
        0.0,
        1.57079632679,
        0.785398163397,
        0.0,
        0.0,
q_init = np.array(
        0.0,
        -0.785398163,
        0.0,
        -2.35619449,
        0.0,
        1.57079632679,
        0.785398163397,
        0.0,
        0.0,
franka.set_joint_positions(q_init)
    q = franka.get_joint_positions()
    dq = franka.get_joint_velocities()
    tau = 1.0 * (q_des - q) - 1.0 * dq
    action = ArticulationAction(joint_efforts=tau)
    articulation_controller.apply_action(action)
The error I am getting is:
[Info] [carb] Logging to file: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/logs/Kit/Isaac-Sim/2023.1/kit_20231026_163424.log
2023-10-26 20:34:24 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.059s] [ext: omni.kit.async_engine-0.0.0] startup
[0.403s] [ext: omni.activity.core-1.0.1] startup
[0.406s] [ext: omni.assets.plugins-0.0.0] startup
[0.407s] [ext: omni.stats-0.0.0] startup
[0.408s] [ext: omni.client-1.0.1] startup
[0.415s] [ext: omni.activity.profiler-1.0.2] startup
[0.416s] [ext: omni.gpu_foundation-0.0.0] startup
[0.424s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.426s] [ext: carb.windowing.plugins-1.0.0] startup
[0.538s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-10-26 20:34:25 [660ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RKL GT1)
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
|     |                                  |        |     |            | 1e04      | 1f0bed54.. |
|     |                                  |        |     |            | 1         |            |
|     |                                  |        |     |            | 4c8a      | e6537608.. |
|     |                                  |        |     |            | 0         |            |
| Total Memory (MB): 31817 | Free Memory: 26668
[1.094s] [ext: omni.kit.pipapi-0.0.0] startup
[1.096s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.096s] [ext: omni.pip.compute-1.2.0] startup
[1.097s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[1.137s] [ext: omni.pip.cloud-1.0.1] startup
[1.138s] [ext: omni.isaac.core_archive-2.2.1] startup
[1.138s] [ext: omni.kit.loop-isaac-1.0.2] startup
[1.139s] [ext: omni.kit.test-0.0.0] startup
[1.140s] [ext: omni.kit.telemetry-0.4.0] startup
[1.156s] [ext: omni.isaac.ml_archive-1.1.3] startup
[1.157s] [ext: omni.mtlx-0.1.0] startup
[1.158s] [ext: omni.usd.config-1.0.3] startup
[1.163s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.164s] [ext: omni.usd.libs-1.0.0] startup
[1.339s] [ext: omni.appwindow-1.1.5] startup
[1.964s] [ext: omni.kit.renderer.core-0.0.0] startup
[2.967s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.969s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[3.066s] [ext: carb.audio-0.1.0] startup
[3.087s] [ext: omni.ui-2.17.3] startup
[3.102s] [ext: omni.uiaudio-1.0.0] startup
[3.103s] [ext: omni.kit.mainwindow-1.0.0] startup
[3.105s] [ext: omni.kit.uiapp-0.0.0] startup
[3.105s] [ext: omni.usd.schema.anim-0.0.0] startup
[3.307s] [ext: omni.usd.schema.physics-0.0.0] startup
[3.331s] [ext: omni.usd.schema.semantics-0.0.0] startup
[3.335s] [ext: omni.usd.schema.isaac-2.0.1] startup
[3.344s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[3.350s] [ext: omni.usd.schema.physx-0.0.0] startup
[3.385s] [ext: omni.usd.schema.audio-0.0.0] startup
[3.390s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[3.397s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[3.398s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[3.402s] [ext: omni.anim.navigation.schema-105.1.0] startup
[3.405s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[3.412s] [ext: omni.kit.window.popup_dialog-2.0.22] startup
[3.417s] [ext: omni.usd_resolver-1.0.0] startup
[3.423s] [ext: omni.kit.widget.nucleus_connector-1.1.1] startup
[3.425s] [ext: omni.graph.exec-0.2.7] startup
[3.425s] [ext: omni.resourcemonitor-105.0.0] startup
[3.428s] [ext: omni.usd.core-1.1.6] startup
[3.432s] [ext: omni.kit.actions.core-1.0.0] startup
[3.434s] [ext: omni.timeline-1.0.9] startup
[3.436s] [ext: omni.kit.exec.core-0.4.1] startup
[3.438s] [ext: omni.ui.scene-1.6.14] startup
[3.445s] [ext: omni.hydra.usdrt_delegate-7.2.23] startup
[3.461s] [ext: omni.kit.commands-1.4.6] startup
[3.465s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[3.466s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[3.475s] [ext: omni.kit.widget.versioning-1.4.4] startup
[3.477s] [ext: omni.usd-1.10.15] startup
[3.539s] [ext: omni.kit.menu.utils-1.5.4] startup
[3.549s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[3.572s] [ext: omni.kit.widget.nucleus_info-1.0.1] startup
[3.572s] [ext: omni.kit.widget.filebrowser-2.3.34] startup
[3.577s] [ext: omni.kit.search_core-1.0.4] startup
[3.578s] [ext: omni.kit.widget.path_field-2.0.7] startup
[3.579s] [ext: omni.kit.notification_manager-1.0.6] startup
[3.580s] [ext: omni.kit.widget.search_delegate-1.0.3] startup
[3.581s] [ext: omni.kit.widget.browser_bar-2.0.8] startup
[3.582s] [ext: omni.kit.clipboard-1.0.3] startup
[3.583s] [ext: omni.kit.usd.layers-2.1.19] startup
[3.593s] [ext: omni.kit.window.filepicker-2.10.3] startup
[3.604s] [ext: omni.kit.menu.create-1.0.11] startup
[3.606s] [ext: omni.kit.window.file_importer-1.0.21] startup
[3.608s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[3.609s] [ext: omni.kit.primitive.mesh-1.0.14] startup
[3.613s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[3.614s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[3.618s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[3.619s] [ext: omni.kit.stage_templates-1.1.20] startup
[3.621s] [ext: omni.kit.widget.filter-1.1.2] startup
[3.621s] [ext: omni.kit.context_menu-1.6.6] startup
[3.623s] [ext: omni.kit.window.file-1.3.41] startup
[3.625s] [ext: omni.kit.widget.stage-2.9.2] startup
[3.636s] [ext: omni.kit.collaboration.presence_layer-1.0.7] startup
[3.639s] [ext: omni.kit.widget.searchfield-1.1.2] startup
[3.641s] [ext: omni.kit.window.drop_support-1.0.1] startup
[3.641s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[3.642s] [ext: omni.kit.widget.prompt-1.0.5] startup
[3.643s] [ext: omni.kit.window.property-1.9.6] startup
[3.645s] [ext: omni.kit.window.content_browser-2.7.14] startup
[3.657s] [ext: omni.kit.widget.live_session_management-1.2.16] startup
[3.661s] [ext: omni.kit.property.usd-3.21.12] startup
[3.670s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[3.672s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[3.673s] [ext: omni.ui_query-1.1.1] startup
[3.674s] [ext: omni.kit.widget.settings-1.0.4] startup
[3.675s] [ext: omni.kit.ui_test-1.2.13] startup
[3.677s] [ext: omni.kit.window.preferences-1.3.21] startup
[3.681s] [ext: omni.kvdb-0.0.0] startup
[3.683s] [ext: omni.convexdecomposition-105.1.9-5.1] startup
[3.688s] [ext: omni.inspect-1.0.1] startup
[3.690s] [ext: omni.localcache-0.0.0] startup
[3.692s] [ext: omni.physx.foundation-105.1.9-5.1] startup
[3.692s] [ext: omni.usdphysics-105.1.9-5.1] startup
[3.697s] [ext: omni.graph.tools-1.41.3] startup
[3.715s] [ext: omni.graph.core-2.139.8] startup
[3.719s] [ext: omni.iray.libs-0.0.0] startup
[3.723s] [ext: usdrt.scenegraph-7.2.23] startup
[3.773s] [ext: omni.physx.cooking-105.1.9-5.1] startup
[3.782s] [ext: omni.volume-0.3.0] startup
[3.790s] [ext: omni.mdl.neuraylib-0.2.0] startup
[3.792s] [ext: omni.physx-105.1.9-5.1] startup
2023-10-26 20:34:28 [3,795ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[3.807s] [ext: omni.kit.numpy.common-0.1.2] startup
[3.808s] [ext: omni.hydra.rtx-0.1.0] startup
[3.820s] [ext: omni.hydra.pxr-1.1.4] startup
[3.826s] [ext: omni.isaac.dynamic_control-1.2.5] startup
[3.836s] [ext: omni.kit.hydra_texture-1.1.10] startup
[3.842s] [ext: omni.mdl-0.1.2] startup
[3.862s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[3.867s] [ext: omni.kit.viewport.registry-104.0.4] startup
[3.867s] [ext: omni.kit.widget.viewport-105.1.4] startup
[3.872s] [ext: omni.kit.material.library-1.3.39] startup
[3.878s] [ext: omni.hydra.engine.stats-1.0.1] startup
[3.884s] [ext: omni.kit.manipulator.viewport-104.0.8] startup
[3.885s] [ext: omni.kit.viewport.window-105.1.9] startup
[3.906s] [ext: omni.physics.tensors-0.1.0] startup
[3.915s] [ext: omni.kit.widget.graph-1.8.4] startup
[3.920s] [ext: omni.kit.usd_undo-0.1.2] startup
[3.920s] [ext: omni.kit.viewport.utility-1.0.16] startup
[3.921s] [ext: omni.physx.tensors-0.1.0] startup
[3.929s] [ext: omni.kit.window.extensions-1.3.0] startup
[3.934s] [ext: omni.graph-1.106.0] startup
[3.982s] [ext: omni.debugdraw-0.1.2] startup
[3.989s] [ext: omni.warp.core-0.10.1] startup
   Devices:
     "cpu"    | x86_64
[4.130s] [ext: omni.isaac.version-1.0.3] startup
[4.132s] [ext: omni.graph.ui-1.48.0] startup
[4.153s] [ext: omni.isaac.core-2.10.2] startup
[5.518s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[5.537s] [ext: omni.graph.action-1.55.0] startup
2023-10-26 20:34:30 [5,530ms] [Warning] [carb] [Plugin: libomni.graph.action.plugin.so] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph.action/bin/libomni.graph.action.plugin.so remained loaded after unload request
[5.584s] [ext: omni.isaac.ui-0.13.2] startup
[5.594s] [ext: omni.isaac.cloner-0.7.0] startup
[5.596s] [ext: omni.isaac.utils-0.5.3] startup
[5.609s] [ext: omni.isaac.gym-0.8.5] startup
[5.611s] [ext: omni.isaac.debug_draw-0.6.0] startup
2023-10-26 20:34:30 [5,606ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[5.624s] [ext: omni.importer.mjcf-1.1.0] startup
[5.639s] [ext: omni.isaac.mjcf-1.0.0] startup
2023-10-26 20:34:30 [5,628ms] [Warning] [omni.isaac.mjcf] The extension omni.isaac.mjcf has been deprecated. Please use omni.importer.mjcf instead.
[5.640s] [ext: omni.isaac.occupancy_map-0.3.1] startup
[5.686s] [ext: omni.importer.urdf-1.1.3] startup
[5.741s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[5.743s] [ext: omni.kit.graph.delegate.default-1.1.1] startup
[5.745s] [ext: omni.kit.graph.usd.commands-1.3.0] startup
[5.747s] [ext: omni.kit.browser.core-2.3.9] startup
[5.753s] [ext: omni.kit.widget.spinner-1.0.5] startup
[5.755s] [ext: omni.kit.window.cursor-1.1.1] startup
[5.756s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[5.759s] [ext: omni.graph.image.core-0.1.0] startup
[5.761s] [ext: omni.kit.browser.folder.core-1.9.7] startup
[5.766s] [ext: omni.graph.nodes-1.106.3] startup
[5.981s] [ext: omni.kit.viewport.menubar.core-105.0.17] startup
[6.005s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[6.007s] [ext: omni.kit.graph.delegate.modern-1.9.0] startup
[6.010s] [ext: omni.kit.browser.sample-1.4.6] startup
[6.013s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[6.016s] [ext: omni.syntheticdata-0.4.10] startup
[6.060s] [ext: omni.graph.window.core-1.84.0] startup
[6.078s] [ext: omni.warp-0.10.1] startup
[6.513s] [ext: omni.kit.window.material_graph-1.8.9] startup
[6.533s] [ext: omni.graph.scriptnode-1.1.6] startup
[6.543s] [ext: omni.command.usd-1.0.2] startup
[6.545s] [ext: omni.graph.window.action-1.11.2] startup
[6.553s] [ext: omni.replicator.core-1.10.10] startup
2023-10-26 20:34:31 [6,636ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[6.790s] [ext: omni.activity.pump-1.0.0] startup
[6.793s] [ext: omni.isaac.core_nodes-1.6.1] startup
[6.828s] [ext: omni.kit.actions.window-1.1.0] startup
[6.833s] [ext: omni.kit.viewport.ready-1.0.5] startup
[6.835s] [ext: omni.isaac.wheeled_robots-0.7.2] startup
[6.859s] [ext: omni.kit.selection-0.1.2] startup
[6.861s] [ext: omni.kit.hotkeys.window-1.4.0] startup
[6.868s] [ext: omni.isaac.kit-1.4.5] startup
[6.869s] [ext: omni.kit.widget.stage_icons-1.0.3] startup
[6.870s] [ext: omni.kit.menu.edit-1.1.13] startup
[6.874s] [ext: omni.kit.widget.layers-1.6.28] startup
[6.887s] [ext: omni.kit.menu.file-1.1.7] startup
[6.890s] [ext: omni.kit.window.stage-2.4.0] startup
[6.895s] [ext: omni.sensors.nv.common-0.0.2-isaacsim.3] startup
[6.905s] [ext: omni.kit.property.layer-1.1.4] startup
[6.909s] [ext: omni.sensors.nv.materials-0.1.1-isaacsim.3] startup
[6.910s] [ext: omni.kit.menu.stage-1.2.3] startup
[6.913s] [ext: omni.sensors.nv.wpm-0.1.2-isaacsim.3] startup
[6.914s] [ext: omni.kit.property.audio-1.0.9] startup
[6.920s] [ext: omni.sensors.nv.lidar-0.1.4-isaacsim.3] startup
[6.927s] [ext: omni.isaac.range_sensor-2.0.0] startup
[6.982s] [ext: omni.isaac.lula-2.1.0] startup
2023-10-26 20:34:31 [6,979ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.lula. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
2023-10-26 20:34:31 [6,979ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.lula' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula' failed to load.
At:
  /home/mocap/Documents/DiffOptIsaac/nvidia_debug2.py(4): <module>
2023-10-26 20:34:31 [6,979ms] [Error] [omni.ext.plugin] [ext: omni.isaac.lula-2.1.0] Failed to startup python extension.
[7.520s] [ext: omni.sensors.nv.radar-0.1.1-isaacsim.3] startup
[7.526s] [ext: omni.isaac.surface_gripper-0.5.0] startup
[7.541s] [ext: omni.kit.property.geometry-1.2.10] startup
[7.546s] [ext: omni.kit.property.camera-1.0.5] startup
[7.549s] [ext: omni.isaac.sensor-9.9.1] startup
[7.638s] [ext: omni.isaac.motion_generation-5.1.1] startup
2023-10-26 20:34:32 [7,636ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.motion_generation. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
    import lula
2023-10-26 20:34:32 [7,636ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.motion_generation' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.motion_generation' failed to load.
At:
2023-10-26 20:34:32 [7,636ms] [Error] [omni.ext.plugin] [ext: omni.isaac.motion_generation-5.1.1] Failed to startup python extension.
[7.920s] [ext: omni.isaac.manipulators-1.1.0] startup
[7.927s] [ext: omni.hydra.scene_api-0.1.2] startup
[7.937s] [ext: omni.kit.property.material-1.8.30] startup
[7.942s] [ext: omni.kit.property.light-1.0.8] startup
[7.945s] [ext: omni.isaac.franka-0.4.0] startup
2023-10-26 20:34:32 [7,943ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.franka. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
    import lula
2023-10-26 20:34:32 [7,943ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.franka' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.franka' failed to load.
At:
2023-10-26 20:34:32 [7,943ms] [Error] [omni.ext.plugin] [ext: omni.isaac.franka-0.4.0] Failed to startup python extension.
2023-10-26 20:34:33 [8,228ms] [Error] [omni.ext.python] ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
At:
[8.240s] [ext: omni.kit.property.skel-1.0.4] startup
[8.244s] [ext: omni.kit.property.transform-1.3.10] startup
[8.249s] [ext: omni.kit.property.render-1.1.1] startup
[8.251s] [ext: omni.kit.profiler.window-2.1.2] startup
2023-10-26 20:34:33 [8,348ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
[8.367s] [ext: omni.kit.property.isaac-0.2.1] startup
[8.370s] [ext: omni.kit.property.bundle-1.2.9] startup
[8.373s] [ext: omni.isaac.quadruped-1.3.2] startup
[8.390s] [ext: omni.isaac.cortex-0.3.5] startup
[8.394s] [ext: omni.kit.viewport.actions-105.0.10] startup
[8.400s] [ext: omni.kit.stage_column.payload-1.0.10] startup
[8.403s] [ext: omni.kit.stage_column.variant-1.0.12] startup
[8.405s] [ext: omni.isaac.scene_blox-0.1.0] startup
[8.409s] [ext: omni.isaac.cortex.sample_behaviors-1.0.4] startup
[8.412s] [ext: omni.kit.viewport.menubar.display-105.0.2] startup
[8.415s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[8.424s] [ext: omni.kit.manipulator.transform-104.6.14] startup
[8.427s] [ext: omni.usdphysics.ui-105.1.9-5.1] startup
[8.468s] [ext: omni.physx.commands-105.1.9-5.1] startup
[8.472s] [ext: omni.kit.manipulator.tool.snap-1.3.1] startup
[8.481s] [ext: omni.kit.viewport.menubar.camera-105.1.6] startup
[8.487s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[8.490s] [ext: omni.physx.ui-105.1.9-5.1] startup
[8.527s] [ext: usdrt.gf-1.0.2] startup
[8.527s] [ext: omni.kit.viewport.menubar.render-105.1.0] startup
[8.531s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[8.536s] [ext: omni.kit.manipulator.selection-104.0.7] startup
[8.538s] [ext: omni.kit.manipulator.prim-105.0.9] startup
[8.546s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[8.550s] [ext: omni.physx.demos-105.1.9-5.1] startup
[8.555s] [ext: omni.kit.property.physx-0.1.0] startup
[8.633s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[8.634s] [ext: omni.isaac.universal_robots-0.3.2] startup
2023-10-26 20:34:33 [8,631ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.universal_robots. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
    import lula
2023-10-26 20:34:33 [8,631ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.universal_robots' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.universal_robots' failed to load.
At:
2023-10-26 20:34:33 [8,631ms] [Error] [omni.ext.plugin] [ext: omni.isaac.universal_robots-0.3.2] Failed to startup python extension.
2023-10-26 20:34:33 [8,940ms] [Error] [omni.ext.python] ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
At:
[8.951s] [ext: omni.physx.camera-105.1.9-5.1] startup
[8.962s] [ext: omni.kit.window.toolbar-1.5.3] startup
[8.966s] [ext: omni.physx.cct-105.1.9-5.1] startup
[8.986s] [ext: omni.rtx.window.settings-0.6.9] startup
[8.994s] [ext: omni.physx.graph-105.1.9-5.1] startup
[9.010s] [ext: omni.kit.widget.live-2.1.3] startup
[9.013s] [ext: omni.physx.supportui-105.1.9-5.1] startup
[9.034s] [ext: omni.physx.vehicle-105.1.9-5.1] startup
[9.051s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[9.052s] [ext: omni.graph.ui_nodes-1.5.10] startup
[9.093s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
[9.096s] [ext: omni.kit.window.commands-0.2.4] startup
[9.098s] [ext: omni.kit.window.console-0.2.9] startup
[9.113s] [ext: omni.physx.bundle-105.1.9-5.1] startup
[9.114s] [ext: omni.kit.window.script_editor-1.7.4] startup
[9.120s] [ext: omni.graph.bundle.action-2.0.4] startup
[9.120s] [ext: omni.kit.menu.common-1.1.4] startup
[9.126s] [ext: omni.kit.window.status_bar-0.1.6] startup
[9.142s] [ext: omni.kit.window.title-1.1.3] startup
[9.146s] [ext: omni.replicator.composer-1.2.17] startup
[9.178s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[9.181s] [ext: omni.replicator.isaac-1.10.1] startup
[9.216s] [ext: omni.replicator.replicator_yaml-2.0.4] startup
[9.229s] [ext: omni.rtx.settings.core-0.5.11] startup
[9.236s] [ext: omni.kit.viewport.menubar.lighting-105.0.5] startup
[9.240s] [ext: semantics.schema.editor-0.3.4] startup
[9.244s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[9.244s] [ext: omni.isaac.urdf-1.0.0] startup
2023-10-26 20:34:34 [9,233ms] [Warning] [omni.isaac.urdf] The extension omni.isaac.urdf has been deprecated. Please use omni.importer.urdf instead.
[9.245s] [ext: omni.isaac.dofbot-0.3.0] startup
2023-10-26 20:34:34 [9,243ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.dofbot. Error: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs. Traceback:
    import lula
2023-10-26 20:34:34 [9,243ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.dofbot' in '/home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.dofbot' failed to load.
At:
2023-10-26 20:34:34 [9,243ms] [Error] [omni.ext.plugin] [ext: omni.isaac.dofbot-0.3.0] Failed to startup python extension.
2023-10-26 20:34:34 [9,571ms] [Error] [omni.ext.python] ImportError: /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.lula/pip_prebundle/_lula_libs/liblula_kinematics.so: undefined symbol: _ZN4urdf9parseURDFERKSs
At:
[9.583s] [ext: omni.graph.window.generic-1.9.3] startup
[9.592s] [ext: omni.kit.window.stats-0.1.4] startup
[9.594s] [ext: omni.isaac.sim.python-2023.1.0] startup
[9.595s] Simulation App Starting
2023-10-26 20:34:37 [12,289ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2023-10-26 20:34:37 [12,289ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[12.382s] app ready
2023-10-26 20:34:37 [13,087ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2023-10-26 20:34:37 [13,087ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[13.340s] RTX ready
[13.772s] Simulation App Startup Complete
  File "/home/mocap/Documents/DiffOptIsaac/nvidia_debug2.py", line 11, in <module>
    import lula
2023-10-26 20:34:38 [13,777ms] [Warning] [omni.core.ITypeFactory] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.graph.action/bin/libomni.graph.action.plugin.so remained loaded after unload request.
2023-10-26 20:34:38 [13,780ms] [Warning] [carb] [Plugin: omni.spectree.delegate.plugin] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.usd_resolver/bin/libomni.spectree.delegate.plugin.so remained loaded after unload request
2023-10-26 20:34:38 [13,782ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
2023-10-26 20:34:38 [13,783ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2023-10-26 20:34:38 [13,784ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2023-10-26 20:34:38 [13,787ms] [Warning] [carb.audio.context] 1 contexts were leaked
2023-10-26 20:34:38 [13,814ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
2023-10-26 20:34:38 [13,823ms] [Warning] [omni.core.ITypeFactory] Module /home/mocap/.local/share/ov/pkg/isaac_sim-2023.1.0/kit/exts/omni.activity.core/bin/libomni.activity.core.plugin.so remained loaded after unload request.
Hi bpeele, I followed your steps and tried the script. But I got a import error when I tried to import pinocchio, the detailed error message is:
2023-11-21 13:07:57 [447,219ms] [Error] [omni.kit.app.plugin] [py stderr]: ImportError: /home/boxing/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/cmeel.prefix/lib/python3.10/site-packages/pinocchio/../../../../lib/libhpp-fcl.so: undefined symbol: _ZNK6Assimp8IOSystem16CurrentDirectoryB5cxx11Ev
At:
  /home/boxing/.local/share/ov/pkg/isaac_sim-2023.1.0-hotfix.1/kit/python/lib/python3.10/site-packages/cmeel.prefix/lib/python3.10/site-packages/pinocchio/__init__.py(6): <module>
May I have some suggestions?
