Hi, I’m pretty new to vGPU configuration but I’m trying to setup a set of R730’s with dual M60’s to host multiple 4Q profiles vGPU’s on W10 systems. M60’s are set to "graphics" and has NVIDIA-vGPU-VMware_ESXi_6.0_Host_Driver_361.45.09-1OEM.600.0.0.2494585.vib installed. Profiles can be selected, but after starting the VM this "card" is not displayed in the device manager and no nvidia drivers can be used. Does anyone knows if this vGPU option is actually available for W10 ? Thanks !
sschaber
2
Sounds like you’re not using Enterprise Plus license for ESX which is a requirement.
You won’t be able to use vGPU with Standard…
Related topics
Topic | Replies | Views | Activity | |
Couldn't Install driver to m60-1q or other vGPU in Windows 7 | 9 | 15257 | March 16, 2017 | |
GPU hardware detected but unable to start (error code 10) | 2 | 28242 | June 1, 2015 | |
Couldn't Install driver to m60-1q or other vGPU in Windows 7 | 0 | 8718 | November 17, 2016 | |
Windows 10 not detecting nvidia vGPU on Horizon Desktop | 1 | 10263 | February 3, 2016 | |
vGPU not showing up when creating VM's | 2 | 9136 | May 1, 2014 | |
Drivers wouldn't install win 7 x64 | 4 | 15708 | May 3, 2016 | |
ESXi 6.5 + Tesla M60 cant start VW | 4 | 15659 | February 19, 2018 | |
[SOLVED] M10 with ESXi 6.5 - vGPU: Device not supported | 7 | 22838 | October 18, 2017 | |
vGPU Profile Selection for virtual machine not populating | 6 | 76578 | May 5, 2015 | |
Tesla M10 card on Nutanix cluster running vSphere v6.5 | 1 | 4079 | December 14, 2017 |
