Hello all,
I’ll try to be brief but thorough. I have a Cisco C240 server with 2 K2 cards installed. The following have been completed:
MMIO above 4GB = Disabled
XenServer 6.2 SP1 installed with updates 2-4 applied
vGPU manager is installed successfully
lsmod | grep nvidia output:
nvidia 9656305 26
i2c_core 20294 2 nvidia,i2c_i801 -
dmesg | grep NVIDIA output:
[ 24.725601] nvidia: module license ‘NVIDIA’ taints kernel.
[ 25.444933] NVRM: loading NVIDIA UNIX x86 Kernel Module 331.59 Thu Mar 13 10:40:07 PDT 2014 -
nvidia-smi output shows driver version 331.59, and all 4 GPU’s available
So far everything looks good according to the nVidia/XenServer guide that came with the vGPU mgr download. However, when I create a VM, I am not presented with any GPU options. After the VM is created, I can then edit the VM but the GPU type only allows me to select “NVIDIA GK104GL [GRID K2] GPU’s (4 GPU’s)” which appears to be simply a passthru.
I followed the guide verbatim, rebooting when necessary. I’ve also uninstalled/reinstalled vGPU mgr without success.
Running out of ideas. Have I missed anything? Not sure where to go from here. Any help is greatly appreciated!
