I’ve executed the steps in Hotfix XS62ESP1005 - For XenServer 6.2.0 Service Pack 1, including the following:
- Install the referenced hotfix.
- Reboot the xenserver.
- Uninstall the NVidia driver.
- install the NVidia driver.
My vGPU’s are working, I just can’t see the new vGPU types. I’m specifically interested in the 220Q profile.
[root@xxxxx nvidia]# xe vgpu-type-list
uuid ( RO) : 2a8497f6-32e5-ce41-3000-8586b102a407
vendor-name ( RO): NVIDIA Corporation
model-name ( RO): GRID K200
max-heads ( RO): 2
max-resolution ( RO): 1920x1200
uuid ( RO) : b901188c-7688-e523-2ec3-ae5b470ff728
model-name ( RO): GRID K260Q
max-heads ( RO): 4
max-resolution ( RO): 2560x1600
uuid ( RO) : ced80d9b-51b2-f807-32b5-fa0aa359b546
model-name ( RO): GRID K240Q
max-heads ( RO): 2
uuid ( RO) : b7270ed3-7e6b-b238-bb4e-4a394442a60a
vendor-name ( RO):
model-name ( RO): passthrough
max-heads ( RO): 0
max-resolution ( RO): 0x0
can you run "rpm –q NVIDIA-vgx-xenserver" on the host to determine the version of the vGPU Manager that is running?
You may have to run the update command instead of the install command.
rpm -Uv NVIDIA-vgx-xenserver-6.2-331.59.i386.rpm
[root@xxxx ~]# rpm -q NVIDIA-vgx-xenserver
[root@xxxx ~]# lsmod | grep nvidia
nvidia 9656305 494
i2c_core 20294 2 nvidia,i2c_i801
As Requested. Thanks for the prompt reply!
MichaelO, stealing your find from before:
“Customers using vGPU must re-install the NVIDIA GRID vGPU Manager for XenServer after applying the hotfix and after rebooting the hosts. Failure to do so will cause vGPU to stop working. For instructions on re-installing the NVIDIA GRID vGPU Manager, see Re-installing NVIDIA GRID vGPU Manager for XenServer later in this article.”
http://support.citrix.com/article/CTX140553
mreiring, please try the above and let us know if that resolves it.
Please make sure that you install the required updates for XenServer as well
Hotfix XS62ESP1001 - For XenServer 6.2.0 Service Pack 1 as an example should be ok.
Erik Bohnhorst | Solution Architect – GRID
NVIDIA Corporation
