I am working for FLIR Systems adding one of our Thermal Cameras to the PX2 eco-systems.
It is working nicely using USB , just the capture, but there are some issues when using the GMSL.
We have a Visible GMSL camera that works, but ours doesn’t. I got some NVIDIA documents recommending to add some SCOPE probes in the PX2 HW but I am afraid of doing that… not sure if it is possible since my kit has this giant sinks, etc.
Has someone done this before? It doesn’t sounds as a good idea, not sure why NVIDIA proposed this.
A second question that I have is:
in order for nvmimg_cc to work, is it really needed to have the FSYNC_LOCK bit activated? Maxim is saying that for one camera doesn’t make sense… but I see this activated In all the GMSL cameras even if I run just one.
I was able to go further and activate that BIT by making FSYNC manually… which again , not sure if makes a difference but I was able to go further in the error messages…
that looks like it started to get a frame and then failed?
before I was just getting a Timeout error after retying 11 times (default number in the source code)
Thanks for your reply.
Where do you set the right video frame size in xx.script, capture config parameter at the top of script or sensor register in the middle of xx.script? If you changes the sensor register, which register did you modify? Is the video frame size related to embedded bottom/top line?
I am facing a similar situation when trying to enable our own GMSL camera using Maxim9876 deserializer - running the nvmimg_cc with our own script:
nvmedia: ERROR: _CaptureThreadFunc: Keep failing at NvMediaICPGetFrameEx for 11 times
