We purchased a sekonix GMSL cameras SF3326-101 N2.0 RGB
We are having trouble to start this camera in RGB mode:
./sample_camera_gmsl --csi-port=ab --camera-type=ar0231
Program Arguments:
--csi-port=ab
--fifo-size=3
--serialize-bitrate=8000000
--serialize-framerate=30
--serialize-type=h264
--slave=0
--write-file=
nvrm_gpu: Bug 200215060 workaround enabled.
Initialize DriveWorks SDK v0.6.54
Release build with GNU 4.9.2 from v0.6.0-rc5-0-g3f25786 against Vibrante PDK v5.0.5.0
TimeSource: monotonic epoch time offset is 1522843702720123
TimeSource: PTP ioctl returned error. Synchronized time will not be available.
TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
SDK: Resources mounted from /usr/local/driveworks-0.6/data/resources
SDK: Create NvMediaDevice
SDK: use EGL display as provided
SDK: Default GPU Device set to device number 0. Total number of devices detected: 2
SAL: identified board as DrivePX2-TegraA
SensorFactory::createSensor() -> camera.gmsl, camera-type=ar0231,csi-port=ab,fifo-size=3,serialize-bitrate=8000000,serialize-framerate=30,serialize-type=h264,slave=0,write-file=,output-format=yuv
CameraGMSL: required FPS = 30, resolution = 1920x1208
***** aurix state *****
CAM_PWR_ON: 0x0
TEGRA_GMSL: TEGRA B
TEGRA_FPDL: TEGRA B
TEGRA_A_HDMI: MXM
TEGRA_B_HDMI: MXM
TEGRA_PCI: TEGRA B
FAN_STATE: UNKNOWN
CAM_PWR_ON: 0x1
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_A_HDMI: UNKNOWN
TEGRA_B_HDMI: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
nvmedia: ERROR: RGGB mode for this sensor version is not supported
nvmedia: ERROR: SetupVideoLink: Image sensor(0) device is not present
nvmedia: ERROR: Init: Failed to setup video link
CAM_PWR_ON: 0x0
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: CameraGMSL: cannot connect to camera
Cannot create driver: camera.gmsl with params: camera-type=ar0231,csi-port=ab,fifo-size=3,serialize-bitrate=8000000,serialize-framerate=30,serialize-type=h264,slave=0,write-file=,output-format=yuv
Error: DW_SAL_CANNOT_CREATE_SENSOR
But in the RCCB mode this camera works, but of course the image is overexposed.
Have any ideas?
Regarding overexposure in RCCB mode, could you please file a bug for this topic?
Please login to https://developer.nvidia.com/drive with your credentials.
And check MyAccount->MyBugs->Submit a new bug to file bug.
Please share ID here to follow up. Thanks.
Could you please update DPX2 PDK(5.0.13.0) and DriveWorks1.2 via SDK manager?
And please refer to the below link for sample_camera_gmsl application.
/usr/local/driveworks-1.2/doc/nvdwx_html/camera_mainsection.html on DPX2. Thanks.
