Making system.img... /home/tms/Downloads/Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf is not found, exiting... Error: Failed to generate images
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/IN/QuickStart.html#to-flash-the-jetson-developer-kit-operating-software
i am performing operations based on this website.
warning: cp -f /home/tms/Downloads/Linux_for_Tegra/rootfs/usr/lib/modules/5.15.136-tegra/modules.symbols /home/tms/Downloads/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.15.136-tegra/modules.symbols
cp: cannot stat ‘/home/tms/Downloads/Linux_for_Tegra/rootfs/usr/lib/modules/5.15.136-tegra/modules.symbols.bin’: No such file or directory
warning: cp -f /home/tms/Downloads/Linux_for_Tegra/rootfs/usr/lib/modules/5.15.136-tegra/modules.symbols.bin /home/tms/Downloads/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.15.136-tegra/modules.symbols.bin
71301 blocks
Making Recovery image…
copying recdtbfile(/home/tms/Downloads/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0.000173824 s, 115 kB/s
Existing sosfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/tms/Downloads/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/tms/Downloads/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/tms/Downloads/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/tms/Downloads/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/tms/Downloads/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/tms/Downloads/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/tms/Downloads/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/tms/Downloads/Linux_for_Tegra/bootloader/bpmp_t234-TE980M-A1_prod.bin) reused.
copying bpfdtbfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0000-a02-3509-a02.dtb)… done.
Existing camerafw(/home/tms/Downloads/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/tms/Downloads/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/tms/Downloads/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/tms/Downloads/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/tms/Downloads/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/tms/Downloads/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv.dtb)… done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra234-p3768-0000+p3767-0000-nv.dtb to rootfs… done.
Making system.img…
/home/tms/Downloads/Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf is not found, exiting…
Error: Failed to generate images for external device
Cleaning up…
i download lastest files:
Tegra_Linux_Sample-Root-Filesystem_R36.3.0_aarch64.tbz2
Jetson_Linux_R36.3.0_aarch64.tbz2
pc is ubutun20.04
extlinux.conf the file does not exist indeed
could you please tell me what the problem is?
The document told you to do this which you probably didn’t do .
$ tar xf ${L4T_RELEASE_PACKAGE}
$ sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
$ cd Linux_for_Tegra/
$ sudo ./tools/l4t_flash_prerequisites.sh
$ sudo ./apply_binaries.sh
