zax
January 28, 2026, 4:07am
1
I’m working on Jp7.0 with thor
I tried to use command to produce massflash blob
sudo ./l4t_initrd_flash.sh --no-flash --massflash 5 jetson-agx-thor-devkit internal
And it produce the mfi as Jp6/Jp5
But the size reached to 300G(our rootfs about 22G)
Our mfi image in Jp6 just about 32G
I found that mfi has 5 repeated bsp_imagesX cause the mfi too large
Is that the feature of Jp7?
Can I have a smaller mfi file that supports simultaneous flash to 5 devices?
JetPack_7.1_Linux_JETSON_AGX_THOR_TARGETS/Linux_for_Tegra/tools/kernel_flash/README_initrd_flash.txt
To create the massflash Thor images you need to prepend the following environment variables.
For Thor:
$ sudo BOARDID=3834 FAB= BOARDSKU=0008 BOARDREV= \
./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 5 --network usb0 jetson-agx-thor-devkit internal
Each of the 5 individual massflash directories is about 8.3GB
ls JetPack_7.1_Linux_JETSON_AGX_THOR_TARGETS/Linux_for_Tegra/mfi_jetson-agx-thor-devkit/unified_flash/out
bsp_images bsp_images1 bsp_images2 bsp_images3 bsp_images4
du -h mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4
20K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/board_configs/t264
56K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/board_configs
29M mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/flash
16K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/bootburn
892K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/bootburn_t264_py
16K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/storage_configs/t264
20K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools/storage_configs
30M mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/flashtools
4.0K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/muxer/tcu_muxer
8.0K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/tools/muxer
4.0K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/flash_workspace/rcm-boot
284K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/flash_workspace/rcm-flash/applet
106M mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/flash_workspace/rcm-flash
284K mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/flash_workspace/flash-images/applet
8.2G mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/flash_workspace/flash-images
8.3G mfi_jetson-agx-thor-devkit/unified_flash/out/bsp_images4/flash_workspace
zax
January 28, 2026, 5:52am
3
Hi whitesscott,
The command I used refer to the guide, and I use internal instead of mmcblk0p1
My rootfs has installed the nvidia SDK component, and I’ve clone the rootfs back from thor. So each directories I made is about 32G
Sorry for missread, 300G is not only mfi, the mfi is totally about 170G.
So Jp7 would pre-create the flash enviroment and it would cause the flash blob to be too large
Is there any command or variable make it smaller or just use smaller number with --massflash?
Unless you had a Thor in recovery mode usb attached to your host computer when you created massflash you need to prepend the board variables like this.
You may want to:
sudo rm -rf mfi_jetson-agx-thor-devkit/ mfi_jetson-agx-thor-devkit.tar.gz
Then run that command. It took my host approximately 10 minutes.
My ~/nvidia/nvidia_sdk/JetPack_7.1_Linux_JETSON_AGX_THOR_TARGETS/Linux_for_Tegra/mfi_jetson-agx-thor-devkit
is du -h 42gb
How did you clone your Thor? If you didn’t use this it might be a solution.
Linux_for_Tegra/tools/backup_restore/README_backup_restore.txt
The NVIDIA Jetson Linux package provides a tool to create a backup image and restore
a Jetson device using the backup image.
Requirements:
- Automount of new external storage devices must be temporarily disabled during
backing up and restoring. On most distributions of Debian-based Linux, you can
do this using the following command:
$ systemctl stop udisks2.service
- Run this script to install the right dependencies:
$ sudo tools/l4t_flash_prerequisites.sh # For Debian-based Linux
- This tool requires the host to have "nfs-kernel-server" service running:
$ sudo service nfs-kernel-server start
Workflow 1: To create a backup image to host storage
and
Workflow 3: To massflash the backup image
Hi zax,
Are you using the devkit or custom board for Thor?
Please also verify with the latest Jetpack 7.1(r38.4.0) to see if there’s the similar issue.
zax
January 29, 2026, 2:09am
8
Hi KevinFFF,
I’m using custom board
but I think it is not relate to the board
My issue is solved, it seems to the feature of jp7
