Hi, We are planning to use a camera which is running with INCK 74.25MHz. I would like to know if i can generate this clock signal on Xavier Pin. How can you program the output pin that is a clock source? Thanks.
The clock source is PLLP it’s programmable. It base output is 408M and the divisor scaler is 0.5, So it could gen 74.1818(408/5.5). Have a check the PLLP_OUT0 in Xavier TRM for the detail.
