Hi all,
Setup
Card: A100
CUDA version: 13.0
MathDx version: 25.06.1
IDE: Eclipse (with Nsight Plugin for CUDA support)
I am trying to get cuFFT’s introduction_example.cu to compile and am having trouble doing so. When I try to compile with the default SM for CUDA Toolkit 13, I get the following error:
error: static assertion failed with “Incorrect SM<1010> value, use SM<1100"> instead. In CUDA 13 sm_101 (Thor) was renamed sm_110.”
I have thus far tried adding the flags -gencode arch=compute_80,code=sm_80 and -gencode arch=compute_80,code=compute_80 respectively, since I’m using an A100. When I do this, the compiler complains about -dlto and recommends I use code_lto_ instead. I did so and included -rdc=true when that was prompted.
Unfortunately, after resolving those issues, I am still getting the assertion failed error I started with. I’m not sure what to try next and my internet searches regarding this issue haven’t returned anything useful.
Thank you for your time and responses.
Edit: Additional information:
For anyone trying to find sm.hpp, it should be in [wherever you installed mathdx]/nvidia/mathdx/25.06/include/commondx/operators/sm.hpp
