Matlab on Jetson Orin Nano (Ubuntu 20.04). Installation problems
Hello everyone! I have a Ubuntu 20.04 on Jetson Orin Nano and MatLab R2023a ISO file.
After the disk image file has already been mounted, when I click on install - it opens as a text document, when through the terminal - an error appears:
./install: 1: exec: /mnt/2023-03-03-01-16-03-00/bin/linux-arm-64/install_unix_legacy: not found
Tell me how to solve this problem. Thanks
Are you following Install and Setup Prerequisites for NVIDIA Boards ?
Does your Matlab iso support Jeton BSP (L4T: linux4tegra)?
It’s recommended to check with the Matlab team to see if it can work on the Jetson environment first.
