[Jetson TK1] Jetpack2.0
hello. I have Jetson TK1 board. I recovery board by using L4T R21.4 ver . it’s successfully.
and I tried to install JetPack 2.0 with host PC. (host PC is ubuntu 14.04 32bit)
I download least JetPack.
In terminal, I write chmod +x JetPack-L4T-2.0-linux-x64.run and execute ./JetPack-L4T-2.0-linux-x64.run.
it create _install folder but it isn’t run.
I can’t see JetPack L4T Installer Window.
I need advice. help me please.
64bit code cannot run in 32bit env…
Hum… then If I used hots PC with ubuntu 14.04 64bit, this problem is solved??
Hi SYJ,
Yes, and you could refer Download and Install JetPack guide if you got other issue about Jetpack, http://docs.nvidia.com/jetpack-l4t/index.html#developertools/mobile/jetpack/jetpack_l4t/2.0/jetpack_l4t_install.htm
Cheers
Thank you very much!!
I’ll try it.
