I am getting frustrating failure of Maya to properly open the Maya geometry cache files with the following message:
file -import -type “USD Import” -ignoreVersion -ra true -mergeNamespacesOnClash false -namespace “yodaheadonlyhighresresult” -options “apiSchema=;assemblyRep=Collapsed;chaser=;chaserArgs=;excludePrimvar=;importInstances=1;importUSDZTextures=0;importUSDZTexturesFilePath=;jobContext=;metadata=[hidden,instanceable,kind];preferredMaterial=none;useAsAnimationCache=0;readAnimData=0;useCustomFrameRange=0” -pr -importFrameRate true -importTimeRange “override” “C:/Users/spltechdesign/Desktop/yodaheadonlyhighresresult.usd”;
// File read in 3.1 seconds.
select -r polySurface3_result ;
// Error: y_derger_1_polySurface3_resultCache1 (Cache File): D:/NoYO/y_derger_1_polySurface3_result may have an invalid cache description or invalid, missing or empty cache file.
Cached Playback: The presence of unsupported Cache File node ‘y_derger_1_polySurface3_resultCache1’ has triggered Safe Mode, and caching is disabled.
You can continue work, but caching has stopped.
Remove animation from ‘y_derger_1_polySurface3_resultCache1’, or delete the node entirely, to resume caching.
I tries re-installing both Audio2Face and Maya, I get the same result. Using the demo file does import a cache file just fine in Maya. I am on Windows, now Maya 2023, I was using 2022, but get the same message.
I tried once the whole body and then made just the head. I have used this app before, I don’t know why it is now not letting me load the cache files. I can send you my file if you wish.
Thanks for your answer, I tried Mesh Separate but nothing changed. I am using single meshes only every time.
Also I should say that it appears the node is added in maya, and the play head moves slowly as if it’s under load, but the mouth doesn’t move on the mesh. It’s as if it’s playing a huge cache file that doesn’t really have animation.
If I upload my file here, can only you get it, or would it be available to anyone on the forum? I am not able to distribute this geometry beyond support.
You can send me a Direct Message on the forum so is not public
Send the USD file, that should be enough.
Thanks for testing the Mesh Separate. Reading your last reply, I wonder if it is caching out the wrong geometry. Send the file over and we can take a look. Thanks
I have kept working on this and testing and clearly my mesh is too high in polys or some other mesh issue exists. I returned to the low res mesh that works and loads cache files from Audio2Face and into Maya just fine. Now I wrap the higher resolution geometry to this and it is working pretty well on my first successful test.
I do need to determine how to host the entire high-res character in Audio2Face with the skeleton andimport mixamo animations in order to make an Omniverse version. thanks
I have the same issue , yesterday i imported the cache and it was working fine and today i tried to import cache file and i got this message below:
Any help please?
