Isaac Sim Version
4.5.0
Operating System
Ubuntu 20.04
GPU Information
- Model: T4
- Driver Version: 535.183.01
Topic Description
In the process of switching from Isaacsim 4.0.0 to to 4.5.0 I noticed that we suddenly have massive memory leaks with the new version.
I created a small repro at the end of this post.
And here the resulting memory footprint when I run the script with version 4.0 and 4.5 respectively:
I also observe new memory leaks from passing numpy arrays to wandb.Video though I can avoid that problem by creating a video file with ‘imageio’ and upload that to wandb.
So far I have not found a similar workaround for uploading plots, since simply creating them seems to already create some memory leakage.
Anyways, I believe that using these packages (wandb and matplotlib) creates memory leaks should be a major concern, regardless of possible work-arounds.
try:
import isaacsim
from isaacsim.simulation_app import SimulationApp # isort: skip
except:
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless": True})
def random_plot():
import matplotlib.pyplot as plt
import numpy as np
fig = plt.figure()
x = np.random.rand(10)
y = np.random.rand(10)
plt.scatter(x, y)
plt.close()
return fig
config = {
"experiment_name": "MemroyLeakTest",
import wandb
wandb.init(
config=config,
name="MemoryLeakTest",
try:
from isaacsim.core.api.world import World
except:
from omni.isaac.core.world import World
world = World(stage_units_in_meters=1.0)
world.reset()
for i in range(1000):
for j in range(100):
world.step()
print(i)
# fig = random_plot()
wandb.log(
"example_metric": i,
"random_plot": wandb.Image(random_plot()),
wandb.finish()
world.stop()
simulation_app.close()
