The mst status command responds with…
MST devices:
mt25418_pciconf0
mt25418_pci_cr0
C:\Program Files\Mellanox\WinMFT>mlxburn -dev_type 25418 -dev mt25418_pci_cr0 -i
mage fw-25408-2_9_1000-MHGH28-XTC_A1.bin
-E- Read a corrupted device id (0xffff). Probably HW/PCI access problem
-E- Can not open mt25418_pci_cr0: MFE_CR_ERROR
-E- Image burn failed: child process exited abnormally
Same as you had
Trying Todds flint command…
C:\Program Files\Mellanox\WinMFT>flint -d mt25418_pciconf0 -i fw-25408-2_9_1000-
MHGH28-XTC_A1.bin -nofs -allow_psid_change burn
Current FW version on flash: 2.6.0
New FW version: 2.9.1000
You are about to replace current PSID on flash - “HP_09D0000001” with a diff
erent PSID - “MT_04A0110002”.
Note: It is highly recommended not to change the PSID.
Do you want to continue ? (y/n) [n] : y
Burn process will not be failsafe. No checks will be performed.
ALL flash, including the Invariant Sector will be overwritten.
If this process fails, computer may remain in an inoperable state.
Burning FW image without signatures - OK
Restoring signature - OK
Now I am seeing
“Insufficient system resources exist to complete the API.” in the device manager.
Trying for a reboot.
