mibd process causing HIgh memory in 2700
hi all,
is there any way to kill mibd process in mellanox os?
we have mellanox switch running onyx version 3.6.8008, memory consume above 90 % all the time, after we look the process, thereis one process call Mibd that consume 30%.
regards,
warid
Hello Warid,
Thank you for posting your question on the Mellanox Community.
Based on the information provided, can you please install the latest version of Onyx which is 3.7.1200. 3.6.8008. We made various improvements regarding CPU utilization and memory usage in the versions after 3.6.8008.
If the problem persists after upgrading to the latest version, we recommend to open a Mellanox Support case for further troubleshooting.
Thanks and regards,
~Mellanox Technical Support
hi martin,
thanks for your reply, because our switch is HP OEM, we already opencase to HP about it.
about upgrading the onyx version, is there any other implication in latest onyx os, because last time we have problem with BFD runing OSPF
regards,
