Do you have any experience with micro HDMI?
Jetson TX1 HDMI signals → NXP signal-conditioning IC IP4786CZ32 → micro HDMI connector (HDMI type D from WE PN: 685 119 248 123).
I have a 2 questions:
– 1st – AC or DC HDMI signal coupling
according the “JetsonTX1_OEM_Product_DesignGuide.pdf” section 6.3.1 HDMI / Figure 19: HDMI Connection Example / Table 42. HDMI Interface Signal Routing Requirements
you require the AC coupling (100nF serial caps on TXC+/- TXD0+/-,1+/-,2+/-),
but the specification for IP4788CZ32 / IP4786CZ32 doesn’t have that serial caps
so the question is, use AC coupling or DC coupling?
(IP4788CZ32 is recommended by NXP for new design)
– 2nd – level shifter for HDMI_CEC and HDMI_HPD (DP1_HPD)
according the “JetsonTX1_OEM_Product_DesignGuide.pdf” Table 40. Jetson TX1 HDMI / DP Pin Descriptions
HDMI_CEC (Open Drain, 1.8V)
DP1_HPD (CMOS – 1.8V)
according the Nvidia Reference Design “P2597_B02_OrCAD_schematics.pdf”
HDMI_CEC page 14 “HDMI connector” is 3V3 from Jetson TX1 side
HDMI_HPD page 14 “HDMI connector” is 1V8 from Jetson TX1 side
so the question is, use 1V8 / 3V3 for both
or copy your ref. design and use:
HDMI_CEC 3V3 - so in this case use a direct connection to the IP4788CZ32 pin 29
(VCC_SYS = 3V3 pin 27 / VCC = 5V0 pin 11 )
and for
I did not find internal AC cap based on IP4788CZ32 datasheet, so these AC cap are needed.
On TX1 chip, HDMI_CEC and DP1_HPD are both 1.8V pins. HDMI_CEC is connected to connector thru a gating circuitry, that is for outside HDMI device’s voltage level and so the level shifter for HDMI_HPD. VCC_SYS is 3.3V, so just copying ref. design is OK .
I hereby confirm the correct operation of my TX1 CARRIER board with micro HDMI (type D) in configuration:
TX1 <=> AC CAP <=> IP4788CZ32 <=> micro HDMI.
Mr Zet and Geoffreywall, I am interested in using this NXP chip as well. Could one of you weigh in on the purpose of the Inverter on the Hot plug that was asked about in the last post? I didnt see anything about an inverter in the documentation either.
