Microsoft DDA and RTX A 4000 / 4500 +
Good morning everyone,
I seem to have run into an issue regarding Nvidias Licensing, sadly our Salesrep and Nvidia Partner was not able to give us a clear answer regarding the following Topic:
Do we need any licensing to use DDA (Passthrough) with an Nvidia RTX A 4000 or 4500 to a VM that is an RDSH Server.
If we would decide to use an RTX A 5000 instead, would that GPU require a licence ?
We couldn’t really find any good information regarding that topic.
You won’t need a license for A4000 and A4500 as these are pure RTX GPUs.
A5000 is a bit different as it could run in RTX mode as well as in Datacenter mode (vGPU support). So it would depend on the mode and the driver in use (RTX<–>vGPU driver)
Hope this helps
Thank you for your quick reply, that helps me alot.
