Midpoint of the Molex 699-pin Connector
Hello.
In Orin Data Sheet dimensions are determined relative to midpoint of connector.
I would like to clarify, is the midpoint the middle of the connector body? 11mm from 22mm connector width?
In molex drawings the center of the pins is indicated, and it have offset from the middle of the connector.
Hi, which dimension do you mean? Can you share a picture of your question?
I mean 20.44 mm to mouting hole dimension.
It is the midpoint of connector notch. The width of 2048430001 is 20.10mm.
Thanks for the quick response.
The connector drawing in the Figure 7-4 is different from the connector 2048430001 drawing.
In reference design, i mesure distance from pin F1 connector J3 to MEC15 and got 20.635 mm.
And since the center of the connector 2034560003 is shifted by 0.2 mm from pin center,
then the correct result is obtained - 20.44 mm from the body center of 2034560003.
