Mechanical M1 and M2 standoffs
M1 M2 Standoff for SODIMM Connector how must be placed on board according to main connector?
Please refer to Chapter 5. Modular Connector for further details in Orin NX Series Design Guide available in download center Jetson Download Center | NVIDIA Developer
Also, refer to 5.5 Module Drawing and Dimensions in Orin NX Series Modules Data Sheet Jetson Download Center | NVIDIA Developer
This wonderful document I saw. But absolutely not clear for instance this look please
Jetson Orin NX Module Dimensions including mounting hole positions are in Figure 5-1 in Data Sheet for the module. Does this answer your question?
If you think that drawing can help, specify please between center of connector and center of hole for standoff. because I don’t see this information on your drawing. And could you please specify which dimension(colored red) because on your step I see little bit different
Please refer to Jetson Orin Nano Developer Kit 3D CAD STEP model. It gives all the locations, dimensions needed and is correct Jetson Download Center | NVIDIA Developer
