MIPI/CSI based ToF camera
Continuing from the discussion on MIPI CSI Camera,
I am currently exploring the compatibility of Time-of-Flight (ToF) cameras with the NVIDIA Jetson AGX Xavier/ORIN platforms. Could you kindly provide information on whether all MIPI/CSI based ToF cameras are compatible with these platforms? If so, I would greatly appreciate details regarding the specific driver used and the JetPack kernel version that includes this driver.
Thank you very much for your assistance.
Best regards,
Siva B
hello billakurthi.siva,
it looks like a depth sensor, please check Jetson Partner Supported Cameras for the camera solutions supported by Jetson Camera Partners on the Jetson platform.
Hi @JerryChang ,
Thank you for your prompt reply.
After reviewing the Jetson Partner Supported Cameras page, I found that only one vendor is listed for ToF cameras. I would like to know if any other vendors’ sensors have been tested or accepted on the NVIDIA Jetson platforms. If so, could you please specify the vendor, as well as the driver and JetPack kernel version used?
Thank you for your assistance.
Best regards,
Siva B
that web page shows everything, please contact with Jetson Camera Partners for further supports.
Sure @JerryChang . I will check with the camera partners. Thanks a lot for your support.
