I am experiencing problems with MIPI CSI camera interface. It seems that there is data corruption on the MIPI interface.
Camera uses 1 lane configuration with 1188Mbps data rate. MCLK is 37.125MHz.
Example of dmesg error logs that I am getting. It shows ECC and/or CRC errors:
[93473.741333] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x00000008
[93473.750043] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00008002
[93473.757903] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00008002
[ 133.505258] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x00000008
[ 133.513954] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000800
[ 133.521782] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000800
[ 4474.130707] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00010000
[ 4474.138540] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00010000
[ 7091.448492] tegra-vi4 15700000.vi: Status: 2 channel:00 frame:0001
[ 7091.454766] tegra-vi4 15700000.vi: timestamp sof 7101742702144 eof 7101758835360 data 0x00200060
[ 7091.464335] tegra-vi4 15700000.vi: capture_id 16064 stream 0 vchan 0
When the corruption happens before streaming has started, the frames cannot be acquired at all.
If it happens during streaming, the error is reported after streaming is stopped.
My test set of SoMs consists of about 20 TX2s and I could divide the SoMs into 2 groups:
- CSI errors never occur (~10 SoMs)
- CSI errors occur very often (almost every other camera streaming operation) (~10 SoMs)
I performed various tests, using different carrier boards and camera modules. The issue definitely stays with the SoM and is easy to reproduce.
I tried old L4T release with kernel 4.4, and the latest L4T with kernel 4.9 - the same errors.
I inspected the TX2 connector - any damage is not visible.
I tried using external oscillator as the clock source - still the same issue.
I have following questions:
- Do you have idea what could cause this kind of failure? Could it be that the TX2s are damaged?
- Is there any way to debug data quality of the MIPI signals on the TX2?
- Is there any way to fine tune the CSI peripheral? I am using cli_settletime = “0”, so the kernel calculates the value itself (cli_settletime=23 in my case)
I will appreciate your help.
Thank you.
