I was developing a Jetson nano mipi driver for a sensor module which transmit data in RAW 8 format. When am reading a data using v4l2-ctl it populates frame start syncpt timeout!0. Here I have attached my dmesg in below.
hello albinraj.c0519,
there’s timeout from VI side for waiting start-of-frame.
is it possible to arrange hardware resources to probe the MIPI signaling?
thanks
Hi Jerry,
Thanks for your reply. Sorry I don’t have any hardware resource to probe the MIPI signals. Is any other method to solve this issue.
may I know which JetPack release you’re working with; there’s RAW8 format type definition with the latest JetPack release.
you may review the default support pixel formats types in the VI drivers, please extend the support formats if necessary.
for example,
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c
static const struct camera_common_colorfmt camera_common_color_fmts[] =
MEDIA_BUS_FMT_SRGGB8_1X8,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_SRGGB8,
since VI engine allocate software buffer following DT property values.
please refer to Individual Imaging Device session and review your device tree properties settings.
thanks
Hi Jerry,
Thanks for your reply. I am using r32.4.3 kernel source and in my camera_common.c file RAW8 format type definition is present but when am trying to build for RAW8 format, its populating unsupported error . Here i have attached my debug trace for driver when am reading using RAW10 format. And also I have attached my dtsi file changes as sensor spec.
Could you please give any idea to move forward using below attachment.
thank you so much.
you may refer to below kernel sources.
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c
for example,
static int extract_pixel_format(const char *pixel_t, u32 *format){...}
you should also extend the support format type to add RAW8 supports.
thanks
Hi Jerry,
Thank you so much for your reply. I have changed my sensor_common.c and imx219 dtsi file and it compiled successfully. But when am reading data from sensor getting same issue(frame start syncpt timeout!0). When am executing command $ v4l2-ctl --device /dev/video0 --list-formats-ext, I can’t see “bayer_rggb” which i made change in dtsi file(Is it really changed to RAW8 format).
Could you please check the attachment and give me any idea.
please also looking into below,
please examine from driver side to ensure VI driver has recognize the format types as RAW8.
for example,
static int sensor_common_parse_image_props()
sprintf(pix_format, "%s_%s%d", mode_str, phase_str, depth);
temp_str = pix_format;
Hi Jerry,
Thanks for your reply, Actually when I build my kernel again it was change to RAW8 format. And also I have examined the pin connection between sensor and Jetson Nano board there is a swap in sensor board so we are working on it. Once we clear it, I will update you.
One doubt I have Jerry. Suppose a senor send 10 packets per second then how to calculate physical_w, physical_h,active_w, active_h and line_length to update dtsi file. Packet length is 256.
Thank You
you may check sensor specification for physical width and height values.
please refer to the sensor readout diagram for the active regions of active_w and active_h property settings; line_length were used for pixel line width horizontal timing size, it must be greater than or equal to active_w.
BTW,
please refer to Sensor Software Driver Programming Guide for the details.
thanks
Hi Jerry,
Thanks for your reply, We have cleared P and N swaping issue still it populating frame start syncpt timeout!0 error.
Kindly suggest any solution for it.
there’re two phases you may looking to for issue debug.
from the hardware side,
may I know is it possible to arrange hardware resources for probing the MIPI signaling? it could helps to narrow down the issue by checking whether sensor is actually streaming or not.
is not, you should check the regulator settings or clock source for the sensor modules.
from the software side,
please refer to Supported Modes and Power Efficiency to configure system as maximum performance mode.
you may also refer to Sensor Pixel Clock session to review your pix_clk_hz property setting.
thanks
Hi Jerry,
I have attached DSO screen shot of Data receiving in Jetson Nano Data Lane 1.
Pixel clock I have calculated using formula (Data rate(MBPs) * num of lane)/Number of bits.
may I know what’s the actual stream it is?
I’ve notice that you’re setting active_h=1 for the sensor mode resolution.
please also refer to Applications Using V4L2 IOCTL Directly by using V4L2 IOCTL to verify basic functionality during sensor bring-up.
thanks
Hi Jerry,
My custom sensor send 4 packets in one second each packet length is 256. that why I gave active_h=1 and active_w=256. Data rate is 225MBps.
Is my configuration is correct.
BTW, how about the embedded metadata height property settings.
is your sensor signaling also sending two rows of embedded metadata?
Hi Jerry,
Thanks for your reply. Sensor not sending any embedded metadata it’s my mistake and I have changed embedded_metadata_height = “0”. I will check this specification and let you know.
One more doubt Jerry. Is any command there to check dtsi file updates done or not from Jetson nano , once OS is updated.
Albin Raj
$ dmesg | grep DTS
[ 0.212258] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
$ sudo -i
# cd /sys/firmware/devicetree/base/host1x/i2c@546c0000/rbpcv2_imx219_a@10/
# cat mode0/embedded_metadata_height
2
$ dtc -I dtb -O dts -o temp.txt tegra210-p3448-0000-p3449-0000-b00.dtb
Hi Jerry,
Thanks for your reply. I have updated my OS with zero embedded metadata. Still its populating frame start syncpt timeout!0 error.
I have tried command
$ v4l2-ctl --set-fmt-video=width=256,height=1,pixelformat=RG8 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=ov5693.raw
When am executing above command it get hang.
Could you please check my dtsi file which i attached and give any idea .
Thank youtegra210-camera-rbpcv2-imx219_dtsi.txt (8.9 KB)
may I know had you also tried the software approach as mentioned in post #13 to configure system as maximum performance mode?
