Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
How can I install the sample files to my target board with such .deb files?
I am currntly also trying to cross-compile the helloword sample file, there is also error when I execute make. Do i need a GPU on my host when I do the cross-compile?
root@docker-desktop:/home/nvidia/build-aarch64-linux-gnu# make
Scanning dependencies of target lodepng-src
[ 1%] Building CXX object 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/src/lodepng.cpp.o
[ 1%] Linking CXX static library liblodepng-src.a
[ 1%] Built target lodepng-src
Scanning dependencies of target glfw-x11
[ 2%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/context.c.o
[ 2%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/init.c.o
[ 3%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/input.c.o
[ 4%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/monitor.c.o
[ 4%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/vulkan.c.o
[ 5%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/window.c.o
[ 5%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/x11_init.c.o
[ 6%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/x11_monitor.c.o
[ 6%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/x11_window.c.o
[ 7%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/xkb_unicode.c.o
[ 8%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/linux_joystick.c.o
[ 8%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/posix_time.c.o
[ 9%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/posix_tls.c.o
[ 9%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/glx_context.c.o
[ 10%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/egl_context.c.o
[ 10%] Built target glfw-x11
Scanning dependencies of target glfw-src
[ 10%] Linking C shared library libglfw.so
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: total time in link: 0.023687
[ 10%] Built target glfw-src
Scanning dependencies of target samples_framework_nocuda
[ 11%] Building CXX object src/framework/CMakeFiles/samples_framework_nocuda.dir/ProgramArguments.cpp.o
[ 12%] Linking CXX static library libsamples_framework_nocuda.a
[ 12%] Built target samples_framework_nocuda
Scanning dependencies of target samples_allocator
[ 13%] Building CXX object src/framework/CMakeFiles/samples_allocator.dir/Allocator.cpp.o
[ 13%] Linking CXX static library libsamples_allocator.a
[ 13%] Built target samples_allocator
[ 14%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SampleFramework.cpp.o
[ 14%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/DriveWorksSample.cpp.o
[ 15%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/DriveWorksSampleSeek.cpp.o
[ 16%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/ProgramArguments.cpp.o
[ 16%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/Window.cpp.o
[ 17%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/Grid.cpp.o
[ 17%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/WindowGLFW.cpp.o
[ 18%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/MathUtils.cpp.o
[ 18%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/MouseView3D.cpp.o
[ 19%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/Log.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/ProfilerCUDA.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/CameraFramePipeline.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SimpleCamera.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SimpleRenderer.cpp.o
[ 22%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SimpleRecordingPlayer.cpp.o
[ 22%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/ScreenshotHelper.cpp.o
[ 23%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/RenderUtils.cpp.o
[ 24%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SamplesDataPath.cpp.o
[ 24%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/WindowEGL.cpp.o
[ 25%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/WindowLinuxEGL.cpp.o
[ 25%] Linking CXX static library libsamples_framework.a
[ 25%] Built target samples_framework
Scanning dependencies of target sample_egomotion
[ 26%] Building CXX object src/egomotion/CMakeFiles/sample_egomotion.dir/main.cpp.o
[ 26%] Linking CXX executable sample_egomotion
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvinfer_safe.so.8, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvinfer_checker.so.8, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvinfer_builder_resource.so.8, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libcufft.so.10, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvrtc.so.11.2, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvrtc-builtins.so.11.4, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so: undefined reference to `nvinfer1::safe::createInferRuntime(nvinfer1::ILogger&)'
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so: undefined reference to `createConsistencyChecker_INTERNAL'
collect2: error: ld returned 1 exit status
make[2]: *** [src/egomotion/CMakeFiles/sample_egomotion.dir/build.make:122: src/egomotion/sample_egomotion] Error 1
make[1]: *** [CMakeFiles/Makefile2:1801: src/egomotion/CMakeFiles/sample_egomotion.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
Here is the error when i cross compile the sample in the docker container
Dear @rlu1 ,
DRIVE OS 6.0.4 is pretty old. Is it possible to upgrade DRIVE OS release? If can’t be upgraded, please share the used cross compilation commands and logs.
Can you check adding the missing libs to LD_LIBRARY_PATH?
its very similar issue.
so either i need to install drive-agx-orin-linux-aarch64-sdk-build-x86:6.0.4.0-0004-patch-01 image or i just flash the latest drive OS?
Dear @rlu1 ,
If you don’t have any dependency on DRIVE OS 6.0.4, we suggest to use latest release. If you have to use 6.0.4, please use drive-agx-orin-linux-aarch64-sdk-build-x86:6.0.4.0-0004-patch-01
