Software Version
DRIVE OS 6.0.4 (rev. 1)
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.3.10904
Host Machine Version
Hi. When I tried sample cross compiling on x86 DRIVE OS docker for Target System Linux aarch64 following this, the cmake and make fail.
First I execute this in docker:
cmake -B /home/nvidia/build-linux-aarch64 -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks/samples/cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK=/drive/drive-linux -S /usr/local/driveworks/samples
In the output ,there are a lot of similar warnings like the following saying there is a cycle in the constraint graph.
CMake Warning at src/calibration/radar/CMakeLists.txt:58 (add_executable):
Cannot generate a safe runtime search path for target
sample_calibration_radar because there is a cycle in the constraint graph:
dir 0 is [/drive/drive-linux/filesystem/targetfs/usr/local/cuda/targets/aarch64-linux/lib/stubs]
dir 2 must precede it due to runtime library [libcublasLt.so]
dir 1 is [/drive/drive-linux/filesystem/targetfs/usr/local/driveworks/targets/aarch64-Linux/lib]
dir 3 must precede it due to runtime library [libdw_base.so.5.6]
dir 7 must precede it due to runtime library [libglfw.so]
dir 2 is [/drive/drive-linux/filesystem/targetfs/usr/local/cuda/targets/aarch64-linux/lib]
dir 3 is [/drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib]
dir 1 must precede it due to runtime library [libcupva_host.so]
dir 4 is [/usr/local/driveworks/samples/3rdparty/linux-aarch64/zlib/lib]
dir 5 is [/drive/drive-linux/filesystem/targetfs/usr/local/driveworks/samples/3rdparty/linux-aarch64/vibrante/lib]
dir 6 is [/drive/drive-linux/filesystem/targetfs/usr/local/driveworks/samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib]
dir 7 is [/home/nvidia/build-linux-aarch64/3rdparty/src/glfw]
Some of these libraries may not be found correctly.
make also fails with such errors:
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvinfer_safe.so.8, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvinfer_checker.so.8, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvinfer_builder_resource.so.8, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libcufft.so.10, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvrtc.so.11.2, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: warning: libnvrtc-builtins.so.11.4, needed by /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so, not found (try using -rpath or -rpath-link)
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so: undefined reference to `nvinfer1::safe::createInferRuntime(nvinfer1::ILogger&)'
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: /drive/drive-linux/filesystem/targetfs/usr/local/driveworks/targets/aarch64-Linux/lib/libdriveworks_visualization.so: undefined reference to `typeinfo for dw::sensors::camera::CameraVirtualRecording'
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: /drive/drive-linux/filesystem/targetfs/usr/local/driveworks-5.6/targets/aarch64-Linux/lib/libdw_dnn_base.so: undefined reference to `createConsistencyChecker_INTERNAL'
/drive/toolchains/aarch64--glibc--stable-2022.03-1/bin/../lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/../../../../aarch64-buildroot-linux-gnu/bin/ld: /drive/drive-linux/filesystem/targetfs/usr/local/driveworks/targets/aarch64-Linux/lib/libdriveworks_visualization.so: undefined reference to `dw::image::addExternalAttributesToAttributesList(dwImageProperties*, dw::core::Context*, NvSciBufAttrListRec*)'
The complete output is here:
make.log (8.3 KB)
cmake.log (85.9 KB)
I also tried to compile those for x86 system, and it works fine. Only cross compiling fails.
Any help is appreciated, thanks in advance.
Best regards,
