Hi Steve,
I get the exact same errors. Unfortunately, this solution did not work for me.
- required libs installed:
reway@hil-003:~ sudo apt-get install libx11-dev libxrandr-dev libxcursor-dev libxxf86vm-dev libxinerama-dev libxi-dev libglu1-mesa-dev libglew-dev
[sudo] password for reway:
Reading package lists... Done
Building dependency tree
Reading state information... Done
libglew-dev is already the newest version (1.13.0-2).
libglu1-mesa-dev is already the newest version (9.0.0-2.1).
libxi-dev is already the newest version (2:1.7.6-1).
libxinerama-dev is already the newest version (2:1.1.3-1).
libxrandr-dev is already the newest version (2:1.5.0-1).
libxxf86vm-dev is already the newest version (1:1.1.4-1).
libx11-dev is already the newest version (2:1.6.3-1ubuntu2.1).
libxcursor-dev is already the newest version (1:1.1.14-1ubuntu0.16.04.2).
0 upgraded, 0 newly installed, 0 to remove and 47 not upgraded.
reway@hil-003:~
- cuda cross compilation libs installed:
reway@hil-003:~ sudo apt-get install cuda-cross-aarch64-9-2
cuda-cross-aarch64-9-2 is already the newest version (9.2.88-1).
reway@hil-003:~
- nvidia driver 396 (GeFoce GTX 745:
reway@hil-003:~$ nvidia-smi
Thu Oct 18 14:40:51 2018
| NVIDIA-SMI 396.54 Driver Version: 396.54 |
| 0 GeForce GTX 745 Off | 00000000:01:00.0 Off | N/A |
| 21% 49C P0 N/A / N/A | 353MiB / 4043MiB | 8% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1053 G /usr/lib/xorg/Xorg 285MiB |
| 0 1892 G compiz 62MiB |
| 0 3542 G /usr/lib/firefox/firefox 1MiB |
reway@hil-003:~$
- paths set:
reway@hil-003:~$ echo PATH
/usr/local/cuda-9.2/bin/:/home/reway/bin:/home/reway/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
reway@hil-003:~
reway@hil-003:~$ echo LD_LIBRARY_PATH
/usr/local/cuda/targets/aarch64-linux/lib:
reway@hil-003:~
Any other idea what could it be causing this error?
