Missing header files in akmod-nvidia-3:570.133.07-1.fc42.x86_64
System: Linux 6.15.6-200.fc42.x86_64
Package: akmod-nvidia-3:570.133.07-1.fc42.x86_64
akmods --force
Checking kmods exist for 6.15.6-200.fc42.x86_64            [  OK  ]
Building and installing nvidia-kmod                        [FAILED]
Building rpms failed; see /var/cache/akmods/nvidia/570.133.07-1-for-6.15.6-200.fc42.x86_64.failed.log for details
Hint: Some kmods were ignored or failed to build or install.
You can try to rebuild and install them by by calling
'/usr/sbin/akmods --force' as root.
 grep fatal /var/cache/akmods/nvidia/570.133.07-1-for-6.15.6-200.fc42.x86_64.failed.log
nvidia/nv.c:30:10: fatal error: nv-firmware.h: No such file or directory
nvidia/nv-dmabuf.c:24:10: fatal error: nv-dmabuf.h: No such file or directory
nvidia/nv-pci.c:25:10: fatal error: nv-pci-types.h: No such file or directory
nvidia/nv-i2c.c:28:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-acpi.c:26:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-cray.c:26:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-dma.c:26:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-mmap.c:26:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-p2p.c:26:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-nano-timer.c:30:10: fatal error: os-interface.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv.c:30:10: fatal error: nv-firmware.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-dmabuf.c:24:10: fatal error: nv-dmabuf.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-pci.c:25:10: fatal error: nv-pci-types.h: No such file or directory
2025/07/18 21:20:24 akmodsbuild: nvidia/nv-i2c.c:28:10: fatal error: os-interface.h: No such file or directory
Installed packages:
Package "akmod-nvidia-3:570.133.07-1.fc42.x86_64" is already installed.
Package "nvidia-gpu-firmware-20250708-1.fc42.noarch" is already installed.
Package "kernel-devel-6.15.6-200.fc42.x86_64" is already installed.
Use an old kernel or update to a nvidia version that supports kernel-6.15
Thank you so much for the pointer. It turns out the nonfree updates repository was inadvertently disabled and the package was not being picked up. One enabled, the issue solved itself via dnf update.
